Wounded
/ Wounded #1
Tchamp
Baldwin Georgia
Power trac PT-2422
I have a 2001 2425 that the tram pump that drives the wheels quit working. Upon removing the lovejoy coupler i found the keyway fubar. (See pic below) does anyone have any suggestion as to resolve this? Called terry and another pump is 6 thousand and some change. I was thinking about machining the half moon key to accomidate a square stock pin and re installing. Any other thoughts?
/ Wounded #3
For the price of $6K vs. doing something to work just like OE, go for it.
McMaster-Carr has some good keys and key stock. My workplace orders a good deal from there.
Be certain to order the undersize or oversize properly. Hardness, material grade, etc.
Since this is on a pump with fluids, I would choose the 416 SS and the B86 rating.
It is rated the same as 316L, but at a far better price.
416 stainless steel key stock is stronger than other stainless key stock and can be heat treated for extra strength. It's corrosion resistant and magnetic. 416 stainless steel key stock is more corrosion resistant than steel key stock.
/ Wounded #4
@Tchamp sorry to see that.
Locktite makes a special keyway repair adhesive, #660. I would use that, and perhaps add a grub screw as well. I used it to repair a wood chipper keyway that has held up to quite a bit of subsequent force.
For less than $6k, I bet a friendly neighborhood machinist could make a new keyway.
All the best,
Peter
/ Wounded
My pressure washer key way did the same thing couple years ago, I tigged the keystock into the engine shaft. Mind you it was a bit lower HP than your's. Another option would be to machine another spot opposite the original.
I like that idea of machining a keyway i will look into finding a machine shop to see if i can get that done. Thanks
/ Wounded #7
$6K = ouch!
I paid $8K for the entire PT425 in 2001. Yikes!
I agree with the suggestions to see if you can have the shaft filled and re-keyed, or the loctite suggestion from Ponytug before spending that kind of money.
/ Wounded #8
What machining capabilities do you have? You could machine a proper keyway (not a half-moon) in a different location on the shaft. However, it appears the shaft was damaged when the key failed. In general, keys and keyways are not the most effective method for preventing shaft rotation. Since the shaft is not hardened, the key will eventually wear down the keyway if exposed to shock loads—though the Lovejoy coupling should absorb these forces if the spider remains in good condition.
Another option, which I prefer, is to pin the shaft to the Lovejoy connector. This involves reinstalling the Lovejoy on the shaft, drilling through both in place, and securing them with a properly sized spring pin. Given the pump's age and likely wear, this approach should keep it functional until the pump itself requires replacement. If you take this approach, support the bottom of the Lovejoy when beating the pin into place to avoid damaging the pump bearings.
/ Wounded #10
I would cut a new love-joy in 1/2 to enable you to clamp it to the shaft with a HD muffler clamp (or cable clamp). Before you do you use the magic key fix or liquid metal or Loctite. Cut the split 90 deg away from key so it compresses the key in the slot. If that doesn't work long enough, drill hole with bolt to tighten the homemade split. Permanent Loctite (typically red, use the right number like 262) alone and clamped should hold it. Since the pump shaft is shot anyway, might as well try to make it work.
/ Wounded #11
Generally a key is not supposed to take all the load. You can, and should, cut a new keyway. Or weld up and re-cut the original keyway. But the shaft looks like the coupling spun on it. This means that any coupling is not going to fit properly on that chewed up surface. The shaft needs to be machined smooth so a new coupling will fit snugly. The new coupling should ideally clamp to the shaft. Why did the first key fail? Was the coupling loose? Was the coupling subjected to an unusual shock load? You need to know why the first key failed before you put the motor back into service so that the repaired shaft doesn't fail.
Eric, who has repaired many keyed shafts.
/ Wounded
I had to really work to get the love joy coupling off of the shafr, it really didnt have any side to side play i was considering drilling through the lovejoy and the pump shaft at the same time then tapping the hole through the lovejoy and pump shaft. Running bolt through and using loctite red. It has two lthreaded allen locks that i can use to pin the shaft to keep from moving side to side (see pic) and i think that would solve my problem untill i can come up with the cash to rebuild the tram pump at a later time.
/ Wounded #13
I had to really work to get the love joy coupling off of the shafr, it really didnt have any side to side play i was considering drilling through the lovejoy and the pump shaft at the same time then tapping the hole through the lovejoy and pump shaft. Running bolt through and using loctite red. It has two lthreaded allen locks that i can use to pin the shaft to keep from moving side to side (see pic) and i think that would solve my problem untill i can come up with the cash to rebuild the tram pump at a later time. View attachment 2685652
The reason the coupling was hard to remove and didn't have much side to side play is because the coupling spun on the shaft and both the shaft and coupling have raised portions as well as depressed portions and the raised portions coincided, making removal difficult. Considering how much one of the motors cost I see no reason to not have a competent machinist repair the shaft as long as the motor internals are OK. The shaft needs to be turned so that it is once again round and the surface is at least 80% complete. Your machinist can source a new clamping Lovejoy type coupling and bush it if necessary for a good fit. Or the shaft could be built up with weld, though I would avoid that if it were my shaft, just because it may weaken the shaft. In any case the motor will require disassembly to make the repair. This is a good opportunity to asses the motor internals. Maybe even find out why the coupling spun on the shaft. If the motor is fine inside then repairing the shaft will save you a bunch of money. In my career as a machinist with over 45 years experience I have done many repairs on hydraulic pump and motor shafts.
Eric
/ Wounded #14
Etpm is dead on.
Without remachining there will be no repair.
It is possible to cut another keyway 90 degrees to the failed one. A good welder could buildup the corner of the keyway without doing much damage to the shaft. But, again, that doesn't fix the damaged shaft. Without the shaft repaired...it will fail again.
The proper way to fix it: pull the shaft, grind the shaft, chrome the shaft, regrind the shaft, recut the key.
Repaired a few in my day.
/ Wounded #15
If you have to tear it down to machine the shaft, that seems like the time to rebuild the internals if the parts can be had.
/ Wounded #16
What would expect this to cost?
/ Wounded #17
I don't know the exact cost because I don't live where you do and I have been retired for a while, plus it depends on how thick the chrome plating would need to be. There are also other plating methods for building up worn shafts that don't involve chrome. But if it was my shaft I would lean toward just cleaning up the shaft, cutting a new key way, and making a Lovejoy type coupling fit. They can be bought with just a pilot hole and are made for machining to size. After boring to size a key way is then broached to suit. Any competent machine shop that does shafting work will have the correct cutters for making key ways as well as a set of broaches for making key ways in bores. I have a couple broaching sets still in my shop and have made many custom broach guides for odd sized and tapered bores. And my shop was not unique by any means.
Eric
/ Wounded
I am considering buying another machine if i could find a good donor or good deal on a good used unit
/ Wounded #20
If you were to repair that shaft today, if it was removed from the motor, the cost would be less than $600.00. I would think it that the price in Georgia would be less.
Eric
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 Brush Cutter (A64553)
2016 New Holland...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A65053)
2014 VOLVO A25G...
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
