Question for draftsmen and pattern makers
/ Question for draftsmen and pattern makers #1
WinterDeere
Super Star Member
Rural 'burbs, north of Philly
John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Here's one for all you draftsmen and pattern makers out there. Yeah, I mean you, @dadohead, @dodge man, @wawajake, and @Grumpycat... among others.
I need to indicate the clocking of a circular hole pattern on the end of a cylinder, relative to a radial hole pattern on the cylindrical face. Or put otherwise, in the attached drawing snippet, I need to indicate the clocking tolerance of the 8x Ø.136 drill pattern in the view on the left, to the clocking orientation of the 16x Ø.1640 THRU holes in the view on the right. I assume I snap a datum on one and use a location tolerance on the other, but not having ever properly learned GDT (I'm EE, not ME), I'm not sure the best way to properly note this.
I intend to specify the tolerance in degrees rotation, not inches displacement.
Thanks!
/ Question for draftsmen and pattern makers #2
I intend to specify the tolerance in degrees rotation baixar snaptube, not inches displacement.
Thanks!
I have been reading through the Tape_EBOOK and the user manual for Seamly me.
I can see that when Seamly Me opens and you click on new file, you can then see measurements as well as Information. Within “information” there is a field to indicate a pattern making system. I don’t quite understand what the pattern making system would be used for. Does that have a function other than indicating/reminding that you are going to use a certain system to make a pattern? Is it supposed to link to those sizing charts on the relevant pages from the books, or is it supposed to automatically check the known measurements that are used in the system?
Thanks for de-railing the thread, on the very first reply. :rolleyes:
/ Question for draftsmen and pattern makers #4
Wow! That's quite an engineering problem. I used to teach GD&T at Deere but haven't thought about it in 10 years!
So you only want to call out the timing (clocking) of the 8x pattern with the 16x pattern? You don't want it to control location, orientation, and form of either pattern?
A couple things: you can dimension the pattern any way you want using basic dimensions (rectangular box around dims). You can even be redundant because they are actually locating the theoretical tolerance zone of the feature. Your GD&T callout then details what that tolerance zone looks like.
The second point: the best way to think about a GD&T callout is to envision a physical fixture that checks just what you want (sometimes check fixtures  are made). Give it some thought. Once you know the fixture, the callout describing the GeoTol can be made.
In dealing with two patterns, I'd probably reference the same primary, secondary, tertiary datums for each pattern and make a "true position" callout for each. This indirectly does what you want and allows you to detail location, orientation, and form for the patterns as required.
One last point: please know that even those who use GD&T on a regular basis don't always get it right. It often leads to confusion and phone calls. If you simply want to clock one pattern to the other... maybe a simple +- dimension would be best.... but let's start with what you think the check fixture looks like.
/ Question for draftsmen and pattern makers #5
This is more technical that I am used to and I do not fully understand the scope but why can't you simply put a note for the tolerance and specification on the side ? this is usually common practice.
/ Question for draftsmen and pattern makers #6
Thanks!
A-A is not shown? The flat surface (surfaces?) in A-A needs to be established in relationship to the radial and axial holes. I'm having trouble seeing the flat surface with 4x of .136 round. Not so sure as to the flat surface and the diameter it is on. But I don't believe the above is complete.
I think I would make a B-B view sliced through the 16x .1640 to show their relation to the 8x of .136 round. And that needs to be tied to the flat(s) of 4x .136. This might all fit in A-A.
/ Question for draftsmen and pattern makers #7
Thanks!
I’m also a little confused about the exact question but I think I understand. You cut a “cross section” through where there are 8 holes. I’d just dimension the angles between the holes at 45 degrees. I’d then cut additional cross sections as needed to show the additional holes. You may need to show an additional top view with cross sections too.
Hey guys, the confusion is all my fault. I'm an EE, who took plenty of drafting classes in high school and college, but my only jobs in drafting were all civil and landscape, so never really got into GDT. Since what I do is very "mechanical", I have to create a lot of drawings, but following one old machinist's advice that "any GDT symbol on a drawing instantly doubles the cost of the part", I've always avoided it.
Anyway, going back to dadohead's point that's been at least partially echoed by a few others, I did not mean to say that the pattern locations are uncontrolled. In fact, they're controlled relative to the centerline of the cylinder. But because we've never had trouble with our fabricator holding sufficiently-tight tolerances on location of these patterns relative to the primary cylinder bore, we don't specify anything beyond the .005" implied global tolerance for all features taken from the imported 3D model.
The clocking issue has come up, because there are actually hole patterns on both ends of the part, and there is extra fixturing cost involved in clocking the pattern on one end of the feature relative to the other. It is usually the case that I need the hole pattern on one end of the part clocked accurately to these Ø.164 radial thru holes, but the pattern on the other end can be "visual only". The machinist has to call me for each new part design we submit, and say, "okay, which patterns need to be clocked accurately to which other patterns?"
What I ended up doing on this drawing, just to get this one submitted for bid, is to put a note "CRITICALLY-CLOCKED TO Ø.164 THRU HOLES" on that pattern of #8-32's, and then put a similar note "VISUAL CLOCKING ONLY" on the hole pattern on the other end. This helps to keep GDT off the drawing, and is clear as day to the one fabricator who's been making these parts to me, but will require discussion and clarification with any new fabricator bidding the job in the future.
That's probably good enough for now, but I'm still interested in how it would be "properly" done, by a real trained draftsman.
/ Question for draftsmen and pattern makers #9
Lol
Yeah... it depends on the supplier. Deere's production parts come in and go to the CMM room (coordinate measuring machine), GD&T programmed, and 30 pc studies run to show capability. This is repeated if any change occurs in the process. We calm the tolerancing way down for prototype parts though.... for the reasons you state above.
Placing in the note section makes sense here:
Pattern X to be timed with pattern Y: +- 2 deg
Simple and captures your intent.
Yeah, only about 1 out of 10 of my parts go on the CMM, and given they're all flavors of a particular type, the machinist already knows the reference planes from which the coordinates are being taken. So we get away without resorting to GDT.
Many of my other parts have very critical dimensions, but are specifically designed such that all critically-toleranced operations can be performed from a single setup, such as shell milling and then boring any tightly-toleranced dowel hole locations in the same setup. The CNC's they run today are so incredibly accurate, that their finished tolerances come down almost exclusively to changing setups (indexing to a new face when part is turned) and to plating thicknesses.
Machine part designers used to have to work a lot harder than we do today, to hold very tight tolerances. It's rare I get anything back from the shop today, where the diameter is out more than half a thou (.0005"), or location of features performed in the same setup are off by more than a few tenths, at least as long as I stick with 6061 and keep my aspect ratios reasonable. Some of the long and skinny turned parts, especially those done in copper instead of 6061, can be a little more challenging. But even there, the machine programing allows them to pretty easily comp out the flex in the part for a given cut depth and travel speed, to where they're still holding close to ±.001 diameters.
/ Question for draftsmen and pattern makers #11
It always takes new engineers a few years to learn to tolerance parts based on what they  need and not what Manufacturing can hold. Sometimes, it just isn't critical so "give them a garage door to ride the bike through". Then Manufacturing has options, costs go down, and (best of all) your phone doesn't ring!
Exactly. Too many just default to .xxx and ±.005" block tolerances on everything, when ±.01" or even ±.05" might be totally fine. I'm pretty careful with that these days, since every dollar spent on trying to hit a tolerance is either coming out of my own pocket, or going onto the product cost and making us a less competitive option.
But I'm also not shy to put ±.002 or tighter, when the tighter spec allows us to increase our spec'd performance minimums sufficient to cover the added cost or yield hit. Tolerance analysis simulations take a long time, but can be easily scheduled to run over a weekend, so it takes very little skin off my back to run them.
/ Question for draftsmen and pattern makers #13
I think I understand the question now. Some of the holes have to be oriented in an exact manner relative to some of the other holes while others don’t. I’d say the way you are doing is as good as any. I’m a retired land surveyor and spent my career working for a civil firm. I did a lot of drafting but nothing like you are dealing with. I have worked a little since I retired but it’s been 2 years since I picked up a drafting pen computer mouse.
/ Question for draftsmen and pattern makers #14
I do that all the time to make sure not to overspecify tolerances. Our standard tolerance block has 4 entries in it:
0.0 +/-0.1
0.00 +/- 0.01
0.000 +/- 0.005
0.0000 +/- 0.0005
(I forget the exact numbers on the 1 and 2 place, but you get the idea)
So I control most things just by the number of decimal places on each dimension. Everything default to 3 places, but I will knock them down to one or 2 everywhere I can. If I need 1/2" diameter rod for a hand tool I just drew up, I list is as 0.5 not 0.500.
So perhaps you can modify your standard tol block to give more options and save yourself time down the road.
/ Question for draftsmen and pattern makers #15
For years I believe JD Horicon drawings were typically using 3 sigma tolerancing (99.7% in control). Geometric Tolerancing is now fully embedded in Engineering and does have its advantages: bonus tolerances.
For example, a true position callout controls location, orientation, and form on a feature of size... but also allows for  bonus. GD&T callout talking: "Ok Manufacturing guy... you've got choices. If you can hold size, orientation, and form on this hole (or pattern of holes) we'll give you a bonus tolerance on location (cause we know it will still assemble). You decide and route the part the most effective way."
I'm retired 10 years but I believe they're honestly past 4 sigma tolerancing now (99.99% in control) on there way to the holy grail: 6 sigma tolerancing.... 3.4 defects/million opportunities! Good stuff.
0.0 +/-0.1
0.00 +/- 0.01
0.000 +/- 0.005
0.0000 +/- 0.0005
Yep, I have the same, except just 3 lines in my title block. Sheet metal gets the x.x thru x.xxx, and precision machined parts get the x.xx thru x.xxxx, with the 4-digit dimensions typically at ±.0002.
Same.
Oh, I take it a step beyond that! I don't even produce fully-dimensioned drawings, only inspection drawings, on machined parts. Essentially, we provide a 3D model (usually .step) with every part, with implied ±.005 global tolerance on the model. Then the drawing only receives hole call-outs and dimensions on anything that differs from ±.005, either because it needs to be tighter or because we believe money can be saved by loosening it. In most cases, multiple operations on a single setup don't benefit from looser than ±.005, that only becomes a cost advantage when having to move the part to a new setup.
Once in awhile, I'll run across a shop that still wants fully-dimensioned drawings, and then I have to decide if it's worth the effort to even work with them. Working with shops that import our model directly into their CAM software yields fewer mistakes, saved time in CAD, and even much more saved time on inspection (both at fab and incoming to assembly). For these reasons, I really shy away from shops requiring fully-dimensioned drawings the last 25 years, although we still have a few, mostly screw machine manufacturers, sheet metal, and plastics.
/ Question for draftsmen and pattern makers #17
Same.
Pretty much the same here. It's all STEP or native CAD sent. All of our prints have only inspection dimensions and a few ref dims like overall size, etc just to help you get oriented. Some prints have only one or two dims on them. When I get someone who wants a fully dimensioned print it is time to say bye bye. Been a long time since anyone has asked for that. Prints often come quite late in the process for us. We mostly do molded plastic parts but a lot of mold makers want the print at time of quoting to see if there are any crazy tolerances or other difficulties, so we often end up scrambling to make prints for that.
2137 (A65055)
2137 (A65055)
2019 Polaris Ranger Crew XP1000 4x4 Gas Utility Cart (A64557)
2019 Polaris...
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
CARORI 4' FINISH MOWER, 3PT (A64278)
CARORI 4' FINISH...
2007 Nissan Frontier Ext. Cab Pickup Truck (A64556)
2007 Nissan...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
