Trying to match or find specific hydraulic fittings
   / Trying to match or find specific hydraulic fittings #1
chipv12
2008 Mahindra 2816
I have an old backhoe attachment for my tractor. I was made in Italy. These fittings are for 1/4" hose and have an inverted flare with 1/2"×20 female end. In other words, the flare is outward instead of inward on a jic connector.
If anyone knows what the term is for these(besides backasswards) or where I could purchase some please let me know.
I will try to attach photos soon
Thanks
   / Trying to match or find specific hydraulic fittings #2
1/4" BSPP fittings is what you're looking for. We just really call it BSP because it's a super common type of fitting in this side of the pond but I call it BSPP in the forum so it doesn't get confused with BSPT that has tapered threads and is not really used in hydraulics anyway.
It has a 60 taper that does the sealing. The male end as the taper going inwards, while the female end (with the nut) has the taper facing outwards.
1/4" BSPP has 19 TPI and close to 1/2" OD.
Thank you very much! That's it.
Never thought hydraulic fittings could be this complex.
   / Trying to match or find specific hydraulic fittings #5
   / Trying to match or find specific hydraulic fittings #6
I buy from these guys.
Surplus Center doesn't carry hose ends, nor do they sell BSPP fitted hoses. If you want just the fittings, go to Discount Hydraulics (.com). Or they will make the hoses for you too. They use YOUR measurements so be accurate.
   / Trying to match or find specific hydraulic fittings #7
I also use Trausch Dynamics. Their web page tends to have better descriptions.
   / Trying to match or find specific hydraulic fittings #8
And here is a list of/for confusion....
  • thread_guide.pdf
   / Trying to match or find specific hydraulic fittings #9
770 hyd hose in Georgia. They usually. An make any hose we need
   / Trying to match or find specific hydraulic fittings #10
Hydhose.com
401 (A52706)
401 (A52706)
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
CAT 930M (A58214)
CAT 930M (A58214)
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
Informational Lot - Shipping (A56436)
Informational Lot...
