Mitsubishi MT250D, rebuild log / questions
   / Mitsubishi MT250D, rebuild log / questions #22
WildBill....I just posted a thread about parting out my MT2501FD. Looking at your post maybe I could get the parts I need, or start over with yours and use mine for parts ???. PM Sent
   / Mitsubishi MT250D, rebuild log / questions #23
Wow, what a great inspiration.
I just bought a nice MT280, also with loader, in great condition except for that it gradually got harder to start since this summer and now wont start at all despide new plugs. The valve clearance has been adjusted, injectors have been checked, and no cylinder had less than 300psi but still doesn't run. Seems to bleed at least a bit when losening the nuts on the injectors, but don't know if fuel can still be the issue.
Based on your experience, have any good input so far?
Haven't picked it up yet, but was a great price.
Regards
David from Sweden
   / Mitsubishi MT250D, rebuild log / questions #24
Hi. I got also a MT2501D tractor, I changed the fuel filter and came across an issue. The tractor starts, it revs, but it has no power. I added diesel to the fuel filter bowl, bleed the pump by loosening the hose that feeds it, bleed the injectors one by one by loosening the fuel lines that connect to them. Noticed that the first cylinder, when the fuel line is off, makes no difference on the rev counts (the others do, the engine revs go down). Also, changed the diesel return lines, as they were quite old, a bit of air is in them. I believe the main issue is still air somewhere, but don't know where.. What should I do next?
   / Mitsubishi MT250D, rebuild log / questions #25
Did you change the fuel bowl o-ring and the plastic fuel bowl?
The old plastic fuel bowl will have micro cracks. When the fuel pump pulls fuel, the cracks weep in AIR to the fuel system. This looses power greatly.
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2016 Doyle 10T Tender (A56435)
2016 Doyle 10T...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
