Eaton Fuller 7 speed transmission
   / Eaton Fuller 7 speed transmission #1
Hay Dude
Super Star Member
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Anyone ever have the pleasure/pain of driving one? Or know the transmission extensively?
Not an 8LL, 9 speed, 10 speed, 13speed road ranger or 18 speed. Those are great, but wondering if anyone has ever driven a Eaton Fuller 7 speed?
It’s a twin countershaft transmission, model # T14607B
I owned a Spicer “Easy Shift” 7 speed, but that’s a smaller/lighter duty trans.
   / Eaton Fuller 7 speed transmission #2
Well, I had the pain of driving a few. When I drove ready mix, some of our older trucks had this box. They are heavy duty and I'm not aware of any durability problems with them. I was used to Eaton Fuller 13 and 15 speed RoadRangers and my ready mix assignments were usually 8LL's. The 7-speed worked and shifted fine except it had (IIRC - it's been a lot of years) 3 creeper gears and only 4 road gears with one gigantic step between them, so they were a bit of a dog on the highway. These were behind L-10 Cummins and 3306 Cats. An older driver clued me in to just drive it like a 5 speed, no range shifting and not all those creeper gears, but still a dog.
Drive it like a 5 speed as in skipping lower gears, or skipping over some of the middle gears?
Like start off in 3 and row up to 7? Or use 1 through 5?
   / Eaton Fuller 7 speed transmission #5
As I recall, use 1 thru 5.
This pattern the pattern?
   / Eaton Fuller 7 speed transmission #6
   / Eaton Fuller 7 speed transmission #7
That's 1 thru 5 on the main transmission, which on the shift pattern would be LO, 4, 5, 6, 7.
Sorry for confusing things.
Above is the shift pattern for the twin countershaft heavy duty Eaton/Fuller. It requires double clutching until you get familiar enough with it to shift without clutch.
Below looks like the Spicer “EZ shift” 7 speed I had in my 94 International. This was not a twin countershaft and did not require double clutching. You shifted it like an ordinary pickup truck manual transmission.
No....this pattern:
Thats a different pattern than the “straight 7”.
That has a electric shifted lo-hole switch. Never saw one.
   / Eaton Fuller 7 speed transmission #10
When I was an apprentice ( about 40 years ago ) we had some old hi-line trucks that we used all the time that had a transmission with 2 gear shift sticks, seems like we did most of the shifting with the far right stick and the left stick was more of a hi-lo/ super low type gear, but I think they were like 5 speeds with reverse in the main gear shift pattern, it's been a long time but I could still drive one today after studying it for a minute, it used to be comical watching anybody new to the crew jump in the cab and see those 2 gear shift sticks.
PALLET OF PICKUP HITCHES (A50854)
PALLET OF PICKUP...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
