/ Your last generator Maintenance Run #7,261
We have a Generac 22KW 2014 air cooled in the Pacific Northwest.
We had to evacuate for 11 days because of fire it ran the whole time except for oil check every few days, and never an issue with overheating and it was in the summer months, it runs on propane! Still has the original battery!👍🏻☮️✌🏻
/ Your last generator Maintenance Run #7,262
If you go with a 3600 rpm liquid cooled… better be far from the house. There way way more noisy than any 22 kw air cooled running same rpm.
Why would a liquid cooled engine of the same power, running the same rpm, as an air cooled engine, be noisier?
/ Your last generator Maintenance Run #7,263
I'm kind of confused also, I had a 17kw air cooled previously and a 25kw water cooled that I'm about to install, the 25 is definitely quieter then the 17.
/ Your last generator Maintenance Run #7,264
Because the water cooled engine has a sound absorbing water jacket whereas the air cooled engine only has cooling fins cast into the cylinder block and they amplify the sound of combustion as well...and usually the valve clearances on an air cooled engine are greater than a water cooled engine and that also contributes to increased mechanical noise.
On my 21KW air cooled Generac up by the house, I will say the cooling fan noise overcomes everything else.
My 32KW diesel powered Generac is much quieter actually.
/ Your last generator Maintenance Run #7,265
Agreed, however grsthegreat said that the water cooled was noisier then the air cooled.........
/ Your last generator Maintenance Run #7,266
As a rule the liquid cooled are 4pole and run at half the RPM (1800, not 3600)
/ Your last generator Maintenance Run #7,267
Not necessarily, there are a lot of 3600rpm liquid cooled units out there. My 25kw is 3600, uses a Mitsubishi 1.5L 4cyl, same engine that was put in the Mirage.
/ Your last generator Maintenance Run #7,268
Its 3 times the size, and moves a tremendous amount of air. I can stand next to a 22 kw running, with lid closed and talk to the customer. Absolutely impossible on the 45, even if you yell. Its horrible.
/ Your last generator Maintenance Run #7,270
Not right exactly. Diesel gensets are 4 pole / 1800 rpm. Gas is 2 pole / 3600 rpm. I own both btw. Gas can be water or air cooled but diesels are almost always water cooled. In fact I don't know of any major producer that uses an air cooled diesel engine.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
1995 John Deere 7400 (A60462)
1995 John Deere...
2012 Freightliner Cascadia (A61307)
2012 Freightliner...
FLARE STAND (A60736)
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
