GR2120 vs BX?
/ GR2120 vs BX? #1
Newhampster
None het
We recently moved to a new home in southern NH. We have a 2 acre lot with no landscaping at the moment. So I will need something to mow the lawn, help out as we garden, and remove snow from a 75’ long driveway. By the time I add a mower deck and a plow blade, both of these machines seem very pricey. The BX can do more, but at a higher cost, larger size (will need a bigger shed), and a larger turning radius.
What do you recommend?
/ GR2120 vs BX? #5
I'd go with the BX with a 5 ft MMM....and a FEL...and a 5 ft rear blade for snow and light grading.......and... After that, maybe a walk behind tiller for a small garden. Then you will know what you need .....for sure. My trade in on my first Kubota (BX) was a fair price when I moved up to a "B" size for my three acres.
Cheers,
Mike
/ GR2120 vs BX? #8
You can do a lot more with a BX. A BX is pretty common used also. I was looking at the same two 15 years ago and I am so glad I bought the BX. I owned it 10 years and out 800 hours on it, a solid machine. I’ve since moved on to a larger John Deere.
/ GR2120 vs BX? #9
My BX replaced a riding mower 20 odd years ago. 4500+ working hours later I have never regretted that move. Added a bigger machine to give the little feller a break a couple of years ago. Still use it almost daily, well I have flat right now and too cold to fix
Just the effort saved with the loader vs shovel/wheel barrow is the worth the cost to me. Opened up a whole new mindset to projects. My LS with a backhoe expanded the horizons that much more.
/ GR2120 vs BX? #10
Used BX or negotiate for a new one. I got my Kioti CS2520 for 72% of list. Happy so far with it. Twin hydro pedals. I don't care for the BX tread pedal.
/ GR2120 vs BX?
I’m looking at the various tractor dealers near me. There is a JD dealer just a couple miles away, but the list prices on a 1025r? Holy cow! You can get that thing over $30k in a heartbeat.
Unfortunately, the Kubota and Kioti dealers are 30 minutes away. There is a Bobcat dealer close by, which is similar (identical?) to a Kioti subcompact.
/ GR2120 vs BX? #12
I went to the local JD dealer for some quotes. First off the salesperson acted like I was bothering him, and second there was no wiggle room or discounts. I went in to price out an X750 with 60HC deck, and it was more than the Kioti CS2520 with 60 deck I bought. That JD dealer is now out of business, most likely due to their business practices and lack of good salespersons.
My Kioti dealer is 45-50 minutes away. Not happy about that, the Kubota dealer is about 10 minutes away. If Kubota would redesign their treadle pedal to a more friendly twin pedal arrangement, I would most likely own a Kubota, even though the quote was $3K above what the Kioti cost me.
I have several friends with hydrostatic Kubota tractors, and they say they aren't fond of the treadle pedal either. Going forward is fine, but when backing up, especially when blowing snow with a rear blower it gets cramping for them with twisting their body for rear viewing and having their heel in the reverse part of the pedal to back up.
You should maybe drive the 30 minutes to each of the dealers and test drive both.
There is no frame comparison to a lawn tractor frame, and a BX, CS, or 1025r compact tractor frame. All are designed for heavy usage and less likely to twist during regular operations. Over decades they with not fatigue with thousands of hours of use.
Some JD model 1025r have some front-end issues with the steering. You should research that.
My personal opinion is that Kubota is a better built tractor that the Kioti. But I bought a Kioti. I'll see how it goes. So far mostly happy with it.
The hydrostatic filter placement under the floor deck is a beast to get to and replace. Kioti used to have a bolted in removable frame strengthen plate on the lower frame rails. On my model that bolt on option is gone, the plate is now welded in place. Most likely as a cost cutting design maneuver. While it does make the frame stiffer by welding, it makes getting to the hydrostatic filter a real bear. If you do buy a Kioti, I'll instruct you as to removing the floor pan, and slipping a oil filter band wrench into a very limited space and loosening up the filter. I did not have to remove the mowing deck either.
TYM and other brands are available, you can get a TYM and have decades of good operational service. All brands sometime have lemons.
You should do a lot of homework before you buy. Test drive all of them.
/ GR2120 vs BX? #13
BX is a nice tractor if it was 70% of its cost. Seems like right size for what you want to do, but I would shop or look used.
/ GR2120 vs BX? #14
I’m lucky I bought my John Deere before Covid. I was calling about a used one and he offered to shoot me a price on a new one. There was significant discounts at that time and they had a salesman who specialized in homeowner sized tractors and riding mowers. The Kubota dealer never returned my call. 15 years ago it was the opposite JD acted like they didn’t want my business and Kubota did.
/ GR2120 vs BX? #15
Do you have a Massey Ferguson dealer nearby? I've had my 25hp TLB (GC1720) since 2018, 480 hours, and very happy. FEL, 60" mid mount mower, backhoe( for wife projects), rear tiller, other small implements. I would probably not get backhoe again, but it has been a lot better than a mattock and shovel.
/ GR2120 vs BX? #16
I bought a GR 2120 new, needed 4WD, good mower when going, at 750 hrs the trans failed, $2,500 to repair, have since discovered that its not a question of if it fails, but when. Supposedly the newer ones have a modification, however a well serviced, cared for machine should not have a major failure at 750 hrs.
/ GR2120 vs BX? #17
Personally I would buy the BX without the MMM. Bit a zero turn mower for less money than the MMM. Less Hrs on tractor too. My dealer recommended that 12yrs ago.
Just replaced a Cub Cadet zero turn that I bought with my BX. No regrets !!!!
B
/ GR2120 vs BX? #18
I’m in southern NH as well, and I own a BX with about 1000 hours on it. Veterans usually say to always get the bigger machine if you’re at a choice point. They’re right. You will find yourself wishing you had got the bigger machine. And remember, these things hold their value well- the 16k I paid for it new in 2015 seems like short money now, considering how much work I’ve done with it and the resale value being so high.
/ GR2120 vs BX? #19
I’d like to know where people are buying zero turns for the price of a mid mount. Mid mounts aren’t cheap but your talking less then $3k. Yeah you can get a zero turn for that but not a very good one.
/ GR2120 vs BX? #20
Yanmar SA325 at the local dealer $16900
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
SUKUP 4R30" HI-SPEED SHIELDED CULTIVATOR (A64276)
SUKUP 4R30"...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
ASSORTED STIHL POLE SAW PARTS (A62613)
ASSORTED STIHL...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
