Yanmar SA424 possible water contamination in Hydraulic Fluid
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #1
Hulaballoo
Yanmar SA24
I bought a used Yanmar SA424 and immediately changed all fluids and filters. The tractor ran great all summer, but I was slow to address a small leak in one of the backhoe lines. I topped up the fluid in the fall, and noticed that the steering was stiff initially when cold, but would return to normal after the tractor warmed up. But in really cold weather, all of the hydraulics are stiff, bordering on non-functional.
I didn't have easy access to the yanmar branded TF500a, so went with the "equivalent" Mobilfluid 424, and initially thought that it might be too thick in cold weather. I just went out the garage to read the fine print from the nearly empty 5 gallon bucket, and when I lifted it I heard something solid slide across the bottom. I cut the seal, opened the bucket and found a good sized chunk of ice. My best guess is that the bucket got temporarily stored outside, water pooled in the lid, then leaked through the "handy" vent on top of the lid. I'm afraid that when I topped up the fluid (approximately 1 liter) I put in mostly water.
So a couple of questions...
1. What are the chances that I've damaged something?
2. Do these tractors have any ability to purge water from the hydraulic system? (I understand that I'll likely have to drain and refill, but even then there will surely be residual fluid)
3. Is a fluid change enough, or will I need to flush as well?
4. I imagine I should do both filters as well?
I appreciate your experience, as I am pretty new to tractors.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #2
👍Good explanation of the situation, that helps a lot here.
Water can't leave the system without your help.
Probably no serious damage.
You'll likely need to work the remaining water through my changing filters and moving all the cylinders power steering etc.
Parker makes a filtration unit to run your fluid through to eliminate water. Sunbelt or United used to rent them. Not necessary. Flush, check, repeat will work
'Hydraulic filtration cart'
Source the right fluid for the tractor, enough to refill and drain. Water mixed in hydraulic fluid and aerated by use, makes it look a milk shake. When it's clear you've gotten it out of suspension (mix) but there could be a bit of water in the reservoir which for you is probably the trans-rear end housing. Bottom draining the fluid(sometimes there's more than one drain plug) should send most tank water out, jack the tractor up if necessary to get all you can.
Back to regular maintenance, deal with any seals, fittings or hoses that need attention and tractor on. They're tough and you caught it pretty fast in tractor years.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #3
What do you mean by "really cold weather"?
As I'm sure you know oil and water generally don't want to mix, especially when they're in a static state such as in your oil bucket. So how much water, if any, was poured into the system seems like it would be minimal. But if water did get into the system, it won't remain separate from the oil. That's because in a pump driven system like the hydraulics on your tractor, the heat and pressure will cause them to mix, and emulsifiers in the oil will cause them to stay mixed. If there's enough water in the system to be worried about, the oil will show visible contamination. Usually a heavily clouded or even milky appearance.
It is possible that this tractor would be happier with a different oil, and by all means try replacing the oil if that will give you peace of mind. If you decide to replace the oil, you might as well replace the filters again so that you get full life out of this service.
In my experience, hydraulics in general are pretty sluggish and somewhat whiney below -10°C. I let the tractor run at a speed slightly above idle for at least 5-7 minutes after starting it in those temps. 10-15 minutes at -20°C and below. Keep in mind there's no combustion happening in that system to help speed up the warm-up, and it's a big reservoir. It takes time.
Thanks guys. I'd like to think that no damage has been done too, but a note in the operator's manual about operating a cold hydraulic system before adequate warm up time had me worried. I tend to be gentle on machines in general though; I've never even brought mine up to full rpms, so hopefully any effects of oil contamination would be minimized as I was only barely above idle when these symptoms presented.
To my eye, the oil in the sight glass does look somewhat less than perfectly clear, though certainly not like I've seen motor oil look after a blown head gasket. I'm a bit baffled that it operates so poorly when I suspect it has so little water in it. My initial estimate of 1L was surely a worst case scenario, since I doubt I added ALL water without noticing. What I mean by poor hydraulic performance is this: The steering will have essentially no assist, whereas normally it is comically overboosted, and all other features, from the backhoe stabilizer legs to the loader, will move when cold (at idle) but only barely, and they shudder as they move, as if sticking.
My plan is this: The machine has been parked on my sloped driveway for a few days, and as luck would have it, the drain plug (and thus low spot on reservoir) is pointed downhill. I'll crack the plug and drain about 1L of fluid out, just in case any water had settled to the bottom. Then I'll tighten the plug, and run the tractor until warm, to suspend the rest of the water in the oil. I'll then drain the remainder, and pull the filters. I'm tempted to drain the filters as best as I can, then reinstall them, at least temporarily. New ones will need to be ordered, besides, I will probably wind up flushing out the new oil before long, and I think there's more water in the hydraulic cylinders (that I can't get out) than the filters anyhow. After I (gently) run the thing for a while, and have new filters on hand, I'll purge and re-fill one more time.
What do you guys think? Also, any ideas on getting as much oil out of the implements as possible? Any chance that propping the loader/backhoe/stabilizer legs up mechanically, then manually exercising the cylinders with the engine off and the drain plug removed might bring more oil down into the reservoir?
Thanks again
Oh, I'm in Northern Colorado. It was probably just a few degrees below freezing when I ran it before, but will get significantly colder in the upcoming days, hence why I intend to drain today. It will hit -11F (-24c) this weekend, and occasionally will get colder than that, though not normally. Your advice for warming fluid closely mirrors the owner's manual.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #5
The more filters you go through here the better you'll feel about the outcome 😁
You can totally manipulate this cyls manually. They'll take a little grunt and then mooooove. So be aware of its path and pinch hazards... The fluid will kinda blast out of the house at first...You can set up a drain pan cover (towel and rubber band or clamp like a diffuser) and clamp the hose from an implement cylinder and manually move it. That way the hose end is secured, flow contained and you have both hands free.
Cylinders can purge a little air on their own. Motor implements kinda the same process if you're able to turn the blade to move the motor a couple revs.
The steering circuit (and the stuff attached to it) is the most sensitive to air, water in my experience.
If anything for the amount of run time since this happened.... Maybe you pushed a seal out somewhere with thick cold fluid. You didn't likely boil the water in the system and cause cavitation (bubble and pressure) damage to the hard parts.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #6
Thanks again
Personally, I'd rather just continue to drain and refill with new fluid, and cycle the hydraulics until I felt any contamination that may have been present, was under control. Manually purging at least 9 cylinders sounds awful, though no doubt it's the more thorough and affordable method.
I'm skeptical that water contamination is the issue, but completely agree that the symptoms sound more severe than my own experience with a cold hydraulic system. Replacing the fluid with good factory spec stuff is a logical first step.
I'll pay more attention to how mine reacts cold this Sunday. It's going to be in the -20s, so should be as good a comparison as any.
Racing a cold front, I started work before receiving suggestions. I didn't consider, removing hoses, but probably would have tried my simpler way first anyhow. When cracked, the drain plug initially released what was probably 1 tablespoon of water, then another cup of two or diluted oil. I recapped as planned, then started the tractor and let it idle for 5 minutes or so. I raised all implements to their max elevation, shut the tractor down and drained about 4 gallons of what looked a lot like homemade carmel. Mmmm. I had a small helper hold valves open while I moved implements around, which got very heavy without the assistance of hyd fluid to hold them up, but which had the desired effect of re-starting the flow of fluid into the drain bucket. I removed and drained the filters, then reinstalled. I've got 5 fresh gallons of Traveller brand (J20c compliant) fluid staying warm indoors, and hope to go outside this afternoon to pour it in.
The fluid seemed to have more water in it than I was expecting. It'll take some time to get it out, but I'm hoping that the contamination level of this fluid change is light enough that I can feel good about getting a little use out of it before flushing again. next time I'll put the whole machine on stands so perhaps I can cycle the steering system and maybe even manually turn the wheels while holding the drive pedals.
Now to re-fill. It occurred to me while draining that there is a tremendous amount of air in my system that will need to be purged. I know the tractor has some ability to get this air out itself, but I've given it an extraordinary job to do, so hoping it's up to the task. There is a a not in the manual about wanting to wait after applying new fluid to let it settle before starting it up. I'll balance that with wanting to still have the fluid be warm when I start it.
After that I'll verrrry slowly operate valves to attempt to gently fill cylinders, then repeatedly cycle them to clear the air and mix all of the old oil with the new. How does that sound?
If you think of any other suggestions I'm all ears.
Sean
Here's the just-drained oil sitting in the bucket.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #10
Sean
Holy geez man that oil is not "somewhat less than perfectly clear", as you put it lol. Yeah that's a lot of water contamination. My initial skepticism about water contamination was based on your description of the oil. A picture is worth a thousand words.
As muddy as that looks, I doubt you've done too much harm to the machine. I would let it get fully warm and fully bled between fluid changes (I'm sure you'll need to do at least one or two more). The best way on a hydraulic system to get all the air out, is to give the fluid time to expel the air before cycling more fluid through a cylinder or motor. Every time an operation dumps aerated and slightly frothed fluid into the reservoir, give it time for that air to all rise to the top of the reservoir, or the pump will be sucking aerated fluid and sending it back to the consumers. This will greatly increase the amount of time it takes to get the system properly bled, as well as how much air your pump needs to deal with.
Something like 10-15 minutes of running it to get everything warmed up, then fully stroke one cylinder in one direction only, and let the system run for another couple minutes. Then fully stroke that same cylinder in the opposite direction, and again let the system run for a couple minutes. Repeat for all cylinders, one function at a time. The hotter the fluid is, the faster the air bubbles can rise to the surface and exit the fluid.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #11
-24C here yesterday. I checked the hydraulic functions during the first minute or so of operation and found that although the hydro motor and main pump were as whiney as ever when they're that cold, the cylinder functions all worked basically normally. Including three point hitch lift. The steering assist was a different story, but after about a minute of running, it too was more or less functioning normally.
I still let it run for at least 10 minutes before even moving it. Putting my hand on the hydraulic feed connection at the loader valve, I can start to feel some temperature increase. Ultimately it's how the pump sounds that tells me if I need to give it more time. One of these days I'll put a temp gun on there and measure how long it takes the fluid to get to 5C from those temperatures. I'd like to actually know if I'm wasting time, or if it could use a bit longer of a warm-up.
So I imagined that I'd have more time to work on the tractor, then life happened. I've been mostly out of town for the past couple weeks and down with the flu for the rest. But during a brief period of time at home and upright, I put in warm fluid, gave it some time to settle then started it up (this was before reading the advice to run a single cylinder in only one direction...😕. I let it warm up a few minutes, then I cycled the stabilizer legs in both directions.
After running great initially, the engine began to slow down, and would not react to the throttle at all. Once I could tell it wasn't happy I stopped cycling hydraulics. Ultimately it stalled and would not restart. My first thought was perhaps most of the tank was summer diesel and it gelled; It was pretty cold when I tested, but having the hyd. fluid warm when I poured it in, made me feel good enough to test despite the weather. I did add stabilizer to that 5 gal can of fuel, but don't remember if I added an anti-gel additive.
The other thought came to mind after seeing a warning placard to take the machine to the dealer if it ever tips over and not to attempt a re-start. I have no idea why this would be necessary, but am 100% certain that I'd be asking advice in a place like this before winching the machine to a flat bed and bringing it in. Could it be that too much air in the system (like if the tractor inverted), (or if the owner tried to outsmart the manual and drain contaminated oil from every conceivable hiding place by emptying cylinders that should be full of fluid) could make the pump so difficult to turn that the engine would stall? I look forward to hearing your theories. It's worth mentioning that the engine has always run flawlessly up to that point.
As luck would have it I'm out of town again, so can't try anything until the weekend. But it should be in the 50's(!), so I can rule out the gelled fuel theory.
P.S. Yes, the oil looks terrible. It looked much cleaner through the small sight glass, and before I aerated it in operation.
While I patiently await a reply to my main problem, I'll ask a distantly related question, as I'm hungry to learn about my machine, and Yanmar doesn't make it easy.
As far as I can tell, my tractor has two hydraulic motors... Does this make sense? But it certainly only has one reservoir. All functions, from steering to FWD/REV drive power are hydraulic, so perhaps having multiple motors makes sense. I also see two Hydraulic filters on my machine, but the manual only calls for changing one of them (the bigger one) in the maintenance section. I sourced the smaller one and changed that too anyhow, but it's curious that it isn't mentioned at all in the manual.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #14
The TSC Traveller brand had/has been in a class action lawsuit damaging plenty of Mitsubishi, Kubota, Deere and Yanmar machines for being 'compliant', yet NOT 'meeting' JDM J20C.
The only TSC fluid to 'meet' the JDM J20C (Hygard Deere or TF500A Yanmar) is their Premium Traveler brand.
This product was originally made to FLUSH out water out of the hydraulic system and fuel systems of diesel machines. Drain out the bad fluid, next add 2 bottles to a 5-gallon bucket of diesel fuel, and pour it into the fill port for the hydraulics. At low 1,200 rpms, keep working the 3-point and hydraulics. Work the fluid around. If the hydraulics is used to move the machine, work all gears forwards and back. Then drain and refill with the JDM J20C or TF500A fluid.
I'll have to check to see whether I got the "premium" fluid or not. Probably not, as I was buying cheap stuff since it likely won't be in the machine long. Hopefully it won't do much damage in the short time it will be in there. Thanks for the heads up.
So you're suggesting that I add Seafoam to DIESEL fuel, then fill my hydraulic reservoir with it, drain it then add hydraulic fluid and all will be well? Interesting idea. Certainly would be cheaper than repeatedly flushing with $80 buckets of hyd fluid. I've seen the "removes moisture from oil" ad before, and have wondered how that worked.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #16
The motor gradually dying is a typical symptom of a fuel filter that is pulling in gelled fuel - as the fuel filter becomes progressively plugged with wax and gel. Easiest to just replace the filter. Now is the time to add some serious anti-gel to the fuel tank. Having a bit too much anti-gel won't hurt anything.
50/60 degress F may not be enough temperature to deal with gelled fuel. Don't feel bad, I had some fuel gell on me in our tractor last year in spite of 50 years experience. There is no commercial test for diesel fuel gel point - called "cloud point" - although it is simple to test yourself.
Once it has gelled or has "waxed", there are plenty of articles here on TBN on what to do. Last year on mine I used Power Service 911 and followed that with John Deere TY26787 winter fuel conditioner and de-icer. Be generous with the dose. It may take a few days of near summer temperatures even with the 911. .
Regarding the transhydraulic oil. Your's will most likely be OK. Open center type hydraulic systems can handle some water because of the fluid emulsification additive and because any extra tends to end up at the bottom of the sump and filters.
Sure, take the hyd filters inside...thaw them out, check the gasket and reuse. If yours has more than one filter keep the order the same.
BTW, I used JD HyGard Lo Viscosity in my Yanmars. At one time it was recommended by Yanmar. You want to get the Lo Viscosity HyGard for your/our climate. Most of the trans/hydraulic fluids - even the name brands - do not offer a low viscosity. Yes, HyGard is miscible with other trans/hydraulic fluids. I live in the Colorado mountains and the regular viscosity JD HyGard is just too viscous for our climate.
Travelers is OK as a warm weather flushing oil, but you may flush better using a lower viscosity fluid.
If you read up on what the advertising term "compatible with" really means on cheap trans/hydraulic fluid, you will probably want to end up with a name brand trans/hydraulic fluid in your tractor in spite of the cost.
Yanmars are too nice and precision to risk for pennies.
Enjoy,
rScotty
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #17
No, did you mean to call them hydraulic motors??? Or do you mean hydraulic pumps?
Uh....Here we are ignoring that a hydraulic motor and are hydraulic pump are pretty much the same physically - one is turning a shaft in response to hydraulic flow and the other works exactly vice versa.
It is common for tractors to have more than one hydrauic pump. Our Kubota has four, and one is a "piggyback" with two rotors on a central shaft that extends through parallel pump body castings. So your Yanmar could certainly have several. Or piggybacks.
Tractors with HST transmissions also have a couple of hydraulic pumps (and motors) within the transmission itself....but we don't count those.
The larger main system filter is generally a suction type. Those tend to have fairly thin walls on the cannister and weigh about what you would expect for a filter that size.
Just guessing on the small filter, but some tractors have a smaller micron passing rating "bypass filter" that filters a small amount of fluid for critical areas.
Smaller "bypass filters" are sometimes running at slight positive pressures - they do that so that they can filter smaller particles through special filter media having smaller pores. That means they have to have heavier construction to handle some positive pressure and will be surprisingly heavy - and more expensive.
If you have a shop manual for your Yanmar it will have a hydraulic schematic. If you do, and want, you can post the hydraulic schematic and we can go through that with you. It will answer at least some of these questions.
Luck,
rScotty
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #18
Once the diesel and 2-bottles of Seafoam are in the system, drive the tractor around at the 1200rpms and move anything with the controls for the hydraulics. This way, the water is captured and so is the bad fluid gunk. Then drain.
When we see Yanmars, Deeres, Cub Cadets in a bad way for hydraulics, this is our go to for cleaning the system. Both diesel and Seafoam have lubrication properties too, so nothing in the cleaning will be harsh on the gears, pump(s) or lines. Just keep the rpms low to avoid heat and friction as diesel and Seafoam are thinner in viscosity.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #19
And if you live in higher altitude and colder winters like @rScotty Hygard JDM J20D is the way to go.
/ Yanmar SA424 possible water contamination in Hydraulic Fluid #20
When you say it wouldn't restart, do you mean it was cranking but not starting? Or not cranking, like just a click when the key was turned to start position?
If it was cranking but not starting, likely a fuel issue. Warmer weather may or may not be enough to get fuel moving again. Regardless of what it takes to get it started (filters, anti-gels, etc.), make sure it's running on winter diesel.
If the engine was not cranking after it stalled, or cranked very slowly, then that is another issue entirely and possibly bad news.
The advice about not attempting to start after rollover is due to the risk that engine oil leaked past the rings and into the combustion chamber/swept portion of the cylinder. If this was the case, attempting to start it could cause hydraulic lock and serious engine damage. Nothing for you to worry about in your situation.
2025 Unused SDLGC80 60v Electric Golf Cart (A60352)
2025 Unused...
Snap-On Zeus Diagnostic Machine (A61307)
Snap-On Zeus...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61307)
2017 Yale GLC050VX...
2017 Terex RL4 S/A Towable Light Tower (A60352)
2017 Terex RL4 S/A...
