Which engine is used in the Yanmar YB20 excavator?
   / Which engine is used in the Yanmar YB20 excavator?
Well I ordered the one from FAB HEAVY. But now that I received it and tried to install it, I found out it is definitely the wrong model. Almost all mounting holes are positioned differently. It is basicallay a slightly bigger pump. Also the axle (if that's the correct English word) is longer than the original.
So that is a big disappointment... :)
I will see if I can order it elsewhere and now that I have dismounted my original, I will try to compare it before ordering.
[EDIT: (jan 20, 2025) I updated the attached illustration because I now believe I was mistakingly mentioning the wrong engine code in it ]
   / Which engine is used in the Yanmar YB20 excavator? #22
Sorry for the part mix up, though sadly, not uncommon with older machines.
Now that you have the pump off, can you see any markings, for example part numbers on the pump?
Around here, I would suggest taking the old pump to a marine parts shop that might have Yanmar parts and seeing if the technical person can match it.
In general, around here, a heavy duty long round solid cylinder (rod), and weight bearing, as in a truck, or car has an axle ("As"? in Dutch?), and the smaller versions are referred to as "shafts", (I think "Schacht" in dutch, but that isn't, I believe, the Dutch usage, which is I think "Pomp-as". Sorry, my dutch is terrible.) Either word works axle/shaft. Idiomatically, shaft.
All the best,
Peter
I looked at the old pump. The only identification I can see is "AISIN". After Googling I found this is a Japanese part manufacturer.
But I think I found the correct pump:
So now I am wondering which engine I have.
They list these engines:
2T72
2T75H
3T72HL
3T75HA-S
2T72HLE, 2T72HLE-S, 2T72HLEG1, 2T72HLEG1-S
2GMF, 2GM20F, 2GM20F-YEU, 2GM20FC-YEU,
3GMF, 3GM30F, 3GM30F-YEU, 33HM35F, 3HMF,
3GMFVE
Similar pumps can be found on the FAB Heavy Parts site (and also on Aliexpress).
In general the search term Yanmar 121000-42100 seems to yield correct results.
In the Yanmar documentation for the 3T75H-LTBS the water pump assy seems to have the code D21521-42100, so the 42100 is probably a code for water pumps and D21521 seems to be related to the 3T75H-LTBS engine.
Anyway, I am beginning to think that my engine is NOT the 3T75H-LTBS but one of the abovementioned list. 3T75HA-S seems to be the closest to 3T75H-LBTS, so who knows..... :)
[ IMPORTANT EDIT Jan 21, 2025: Actually the 3T75H-LTBS service manual DOES mention the correct water pump: 121000-42100.
I was mistakingly talking about D21521-42100 which is some kind of code for the entire parts page, or something like that.
Anyway 121000-42100 is the correct water pump for the 3T75H-LTBS, even though water pump suppliers do not list the 3T75H-LTBS in the list of engine codes for this water pump! ]
I think I will order again from FAB Heavy Parts, since they were very quick last time. I ordered on Saturday and I received it in the Netherlands on wednesday.
I will also see if I can return the wrong model.
Keep you posted.
   / Which engine is used in the Yanmar YB20 excavator? #24
2T72
2T75H
3T72HL
3T75HA-S
3GMFVE
Keep you posted.
I wonder if your machine's original engine was replaced.
Near the starter should be the engine ID plate.
The 3T75HA-S could be a true mountable replacement engine.
In the Yanmar YM tractor series,
YM250 UK and EU model. 3T75HA
In the Yanmar Gray Market tractors,
YM1810 3T75H
Several of the Yanmar YB excavators use a 3T75H----
YM1810 3T75H
Thanks, yes, it could very well be possible that my machine's original engine was replaced, given the fact that it has also been transformed from an excavator to a forklift. I tried to find a serial number or engine code near the starter but everything is covered in a thick layer of dust and some grease, so that was not successful.
   / Which engine is used in the Yanmar YB20 excavator? #26
Depending on when the engine was made in what era,
Some engines have the ID near the top, like this 3T75HL
   / Which engine is used in the Yanmar YB20 excavator? #27
It is not all bad to clean things off on occasion. Not only does it make finding part numbers easier, but it reduces the chances of fire. The latter is a large concern here, especially around hay and hay dust, but understandably perhaps less of a concern in the Netherlands.
Good luck!
All the best,
Peter
Good luck!
All the best,
Peter
True, but it was a Sunday evening and already dark, misty and freezing so it didn't feel like the perfect moment. The YB20 is outside at the moment, very close to my tools/workshop. I am concerned about fire though, so I'll clean it as soon as I can. Maybe I'll find the engine ID / serial in the process.
   / Which engine is used in the Yanmar YB20 excavator? #29
Dark, misty, cold, sounds like Northern European winter weather! I can sympathize why getting out and getting even wetter might not have been at the top of your list.
Good luck!
All the best,
Peter
I found yet another site with the pump (I think) I need. This site also mentions all dimensions (photo 2 which I also attached to this reply) plus some useful info about typical causes of failure of this pump and a list of engines in which this pump is used, like (amongst many others) 3T72HL and 3T75HA-S. So it looks like my YB20 does not have the standard 3T75H-LTBS engine. Maybe the original engine was replaced by a previous owner, who knows...
The dimensions are almost the same as the ones I quickly measured. It's just that I took the photo from the other side, so the order of the measured dimensions is the other way around.
   / Which engine is used in the Yanmar YB20 excavator? #31
I know the Log Life coolants out there today are more like water and do not have the slippery feeling between your fingers like the older coolants did. One of the failures is bearing wear mentioned at the link.
Prior, I had listed those other coolants. If they are not slippery enough, then add in 16-ozs (0.5L) of Propylene Glycol coolant, also known as pet safe coolant for RV and Marine.
I run with this one, since I have an organic farm.
Amsoil has PG too,
Amsoil PG is also compatible with fully formulated diesel antifreezes and other organic acid technology (OAT) and hybrid organic acid technology (HOAT) formulations.
ASTM D 6210, D 3306
Caterpillar EC-1
Chrysler MS-7170, MS-9769
Cummins CES 14603
Detroit Diesel 93K217
Ford WSS-M97B51-A1, WSS-M97B44-D
Freightliner 48-22880
GM DEX-COOL
John Deere 8650-5
Mack Trucks CN H
TMC RP-330
US Military CID A-A-52624-A
PG (in concentrate) per Amsoil,
Composition by Weight:
Total glycols, > 92 percent;
Corrosion inhibitors and antifoamants,
= 8 percent; Water, < 1 percent
If you really want a long life coolant for a vintage machine, then PG is the way to go.
Update per Jan 21, 2025 in the morning (in The Netherlands).
I noticed a particular piece on the side of the gear housing that is different on a 3T75H-LTBS, 3T75HA, 3T75HA-F, 3T75HA-F, 3T72HA-N.
In the 3T75H-LTBS service manual a simple "triangular" plate is shown, which is exactly what I see in my engine.
All other engines seem to be different in this regard.
You know what is "funny"? I see now that even the part number for the waterpump in the 3T75H-LTBS service manual was correct all along, 121000-42100.
So the confusion started when looking engine numbers at the parts suppliers websites (eg Fab Heavy Parts).
As long as I would have followed EXACTLY the part number mentioned in the 3T75H-LTBS service manual, which is 121000-42100, I would have ordered the correct water pump, even though Fab Heavy Parts (and most other suppliers) mistakingly DO NOT LIST this as a 3T75H-LTBS water pump.
Long story short (until proven wrong :) ):
My YB20 DOES have the standard 3T75H-LTBS engine, just as it is supposed to have.
The 3T75H-LTBS service manual shows exactly the same "triangular" camshaft/gear housing plate that I can see in my engine.
The 3T75H-LTBS service manual shows exactly the correct part number for my water pump, which is 121000-42100.
I should NOT have looked at the engine numbers mentioned by Fab Heavy Parts, and I should just have ordered the water pump with part number 121000-42100. :)
   / Which engine is used in the Yanmar YB20 excavator? #33
@Jaap good detective work! I'm glad that you have it sorted out. I have had a couple of older engines over the years and learned the hard way, like you, that cross reference numbers fall into the "trust, but verify" category.
I hope that this restores your machine to operation soon, as I'm sure that the horses are still producing manure...
All the best,
Peter
   / Which engine is used in the Yanmar YB20 excavator? #34
Checked the Water Pump Part number and it came up real close. Repl. 121000-42100 and came up with Repl.121023-42100 which several tractors use it. WP-4201 is the Fredricks water pump # for it.
Update per January 30, 2025. Good news.
Yesterday I received the water pump 121000-42100. This time Fab Heavy Parts shipped it using Fedex which took 10 days, whereas the previous (wrong) water pump from Fab Heavy Parts was shipped using UPS which only took 4 days.
Anyway, I received it yesterday and immediately installed it. It fitted perfectly and the engine was up and running in no time. So my tracked Yanmar YB20 "fork lift" with snow plow is back in business.
Fun fact: the box containing this new water pump 121000-42100 was labeled 3T72HL.
So for reasons unclear to me, Fab Heavy Parts (and as far as I know all other suppliers) make the mistake of not listing engine 3T75H-LTBS on the list of engines on which this new water pump 121000-42100 will fit. If you follow their recommendations for 3T75H-LTBS you will get water pump 129327-42100 / 12900142005 / 12800142100 which DID NOT fit on my 3T75H-LTBS engine.
So if I have to order other parts in future, I will pay extra attention and compare the parts for 3T72HL with the parts for 3T75H-LTBS, to make sure I get parts that fit my 3T75H-LTBS engine, regardless of the supplier's engine lists.
Anyway, all's well that ends well. Thanks again to everybody helping me with valuable suggestions.
Best regards from The Netherlands.
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2014 CATERPILLAR 627K SCRAPER (A60429)
2014 CATERPILLAR...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
