How much to cut?
/ How much to cut? #1
CK732
Member
Massy
Finally got around to putting my tire chains on the tractor,now the qustion is how much do I cut off.these are both tires.
/ How much to cut? #2
I'm sorry but, those chains do not appear to be properly installed to me.
You may need to remove or relocate one of the cross chains. You do not appear to have either chain fastened correctly. I'm seeing an inside chain not hooked right in one picture and the other the outside fastener is not being used.
/ How much to cut? #3
You don't need to start a new thread each time you've changed something, just FYI. As I said before, you need to get the chains installed properly before you go cutting anything. Those are not installed properly. You should not be using tie wire for holding anything together on tire chains. Did you watch some of the videos in the link I posted?
/ How much to cut?
Yeah I watched the videos. If I don't use wire they work ther way off the tire.
/ How much to cut?
I put thoes chains on the way they put them on in the video! . The cross link is facing up just like you guys told me to do it so how can they not be right?.
/ How much to cut? #7
Which video? When you say that you put them on like they did in the video, do you mean that you got them onto the tires the way that they did or that you actually installed them (all hooks attached and tensioners in place) the way that they did. You have the cross links facing the right way, so you're on the way. Getting them onto the tires is just a step in installing the chains. If the two pictures that you posted in this thread illustrate how they installed them in the video, then they didn't have the faintest idea what they were doing.
The chains should be installed properly, with all hooks attached as designed and tensioners in place before you start cutting anything. I would recommend doing that. Remove and discard all of the tie wire and get the chains installed, completely, without using any tie wire, and then post some pictures, in this thread (no need to start another) and we can help you go from there.
/ How much to cut?
I took the ends of the chains and put wire though them then though the rim and I drove the chains on stopping a few to fix them.
/ How much to cut? #9
The chain on the right tire looks like it has the inside side chain HOOK on the outside putting the latch on the inside.
/ How much to cut? #10
Ok. Now cut the wire off and finish installing the chains. Everything attached and tight, hooks on the inside, latch hook/cam hook on the outside, tensioners in place.
/ How much to cut?
OK I try to drive it without the wire. That's going to be in a few day when the temp above -.
/ How much to cut? #12
I'm not sure if something is getting lost in translation or what. Don't just take the wire off and drive it. You need to actually get the chains installed properly BEFORE driving the tractor.
2024 CATERPILLAR 289D3 SKID STEER (A64279)
2024 CATERPILLAR...
250 GALLON FUEL TANK (A64280)
250 GALLON FUEL...
Caterpillar 814/815/816F Landfill Compactor Service and Parts Manuals (A63117)
Caterpillar...
PALLET OF MISC (A63291)
PALLET OF MISC...
121A (A63745)
121A (A63745)
2020 ATLAS 2 POST AUTOMOTIVE LIFT (A59912)
2020 ATLAS 2 POST...
