2005 Jinma 354 First Oil Change for me, any tips
   / 2005 Jinma 354 First Oil Change for me, any tips #11
I have a vague recollection of reading here that Jinma uses the same part number, JX0707, for several different thread pitches. Some are metric, some are inches. Mine is 3/4" and I've been using a Fram filter since the beginning.
Update: found this:
"This filter number is associated with three different size and style oil filters. If your filter has this number we will be dimensions to ensure you are ordering the correct filter."
Update: found this:
Well that really sucks, you have to take the filter off to check the thread size then order based on that. I had thought everything on these was metric…haven’t seen any imp threads yet. I guess it’s also possible to use a 48/64”-16 thread instead of the m18x1.5 thread and it would “ kinda fit”. Guess I’ll take the filter off and measure the threads, no other option! Old filter numbers are obscured.
I also found I have 5 gallons of rotella straight 40 wt oil on hand. Would this also be suitable for the oil change? The manual I have shows 40# but maybe the Chinese have other oil standards?
   / 2005 Jinma 354 First Oil Change for me, any tips #14
I've found that my Jinma is very sensitive to the oil grade, if I use anything other than 15W-40 I have trouble maintaining oil pressure and the oil light flickers.
MULCHER (A58216)
MULCHER (A58216)
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
Mini-Excavator Quick Coupler (New/Unused) (A59225)
Mini-Excavator...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2158 (A58376)
2158 (A58376)
35176 (A55758)
35176 (A55758)
