Got my sawmill up and running!!! TIME TO MILL!!!
   / Got my sawmill up and running!!! TIME TO MILL!!! #1
HawkinsHollow
SE TN
Branson 3015R
I bought this sawmill March of last year. Got it reasonably set up but then got extremely busy on my 850 sqft. addition/reno of our house, so the mill went on the back burner.
Well we are back in the house and while it is not done, it is almost there. TIME TO GET ON THE MILL!!! My goal is to at least mill all our big fat floating shelves for kitchen/baths/bedrooms, all of our window/door/base trim, and wall treatment/shiplap ceiling in our screen porch. Feels really good to be moving in the right direction towards making this dream a reality. To do this in a reasonable time frame I will have to take this wood to a kiln to get dried. Which I am fine with, considering I need it sterilized anyways for interior use. Here is the setup. Any tips, warnings, or well wishes are greatly appreciated.
Before you comment about my stack in the foreground. That is just some hemlock we used to practice. It will be used green in the next couple of weeks for a shed project. I promise my good wood will stickered and stacked better.
   / Got my sawmill up and running!!! TIME TO MILL!!! #2
Can you swing by my place in S. Vt?
I've got a pile of hemlock logs that just keeps growing! ;-)
   / Got my sawmill up and running!!! TIME TO MILL!!! #4
Sounds like an excuse to load 'em up and have party cutting 'em up!
   / Got my sawmill up and running!!! TIME TO MILL!!! #5
I was wondering what became of your mill. You stopped posting about it so I (mistakenly) assumed you were sawing lumber full bore.
   / Got my sawmill up and running!!! TIME TO MILL!!! #6
Yeah that is only about 900 miles...each way! That would have to affect the cost of milling those logs!
David from jax
   / Got my sawmill up and running!!! TIME TO MILL!!! #8
   / Got my sawmill up and running!!! TIME TO MILL!!! #9
That is nice to have your own mill set up. That's something I always wanted and saw some good deals on name brand portable sawmills. But over the years running a mill would just be beyond my physical limitations due to the arthritis. Especially now since my son has moved to Iowa with an engineering position because he was always my strong back and the one that figured out things like that. It'll be nice when you can cut your logs to the dimensions so that your lumber comes out and ready to use more or less. Hopefully 2025 will be the year that you get a lot of custom projects building done.
Yessir! I tell you what, it ain't easy. I am only 50 and in decent shape, but a couple of logs and I knew I was doing work. The cuts come out amazingly smooth, 1 or 2 quick planer runs and it is ready to go. Can't wait to see what this thing can do.
Year: 2013 Make: Ram Model: 1500 Vehicle Type: Pickup Truck Mileage: 184,305 Plate: Body Type: 4 (A59230)
Year: 2013 Make...
2008 GMC Savana 2500 Cargo Van (A59230)
2008 GMC Savana...
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
MASSAGE CHAIR (A58214)
2022 CATERPILLAR 299D3 XE SKID STEER (A60429)
2022 CATERPILLAR...
