Mahindra 2538 HST 4WD (Drive shaft)
   / Mahindra 2538 HST 4WD (Drive shaft) #1
bobstorage
Mahindra 2538 HST
Need information on removing and inspecting drive shaft (from rear drive to front axle). Any and all information is appreciated. I suspect either shaft gears or collars are damaged. TIA
   / Mahindra 2538 HST 4WD (Drive shaft) #2
What happens in 2 or 4 wheel drive?
Which gives you propulsion?
In two wheel drive, with front wheels off ground, when turning either wheel there is a sound, like bad bearings, but when mechanically shifting front collar on shaft, noise goes away. In four wheel drive front wheels do not engage.
   / Mahindra 2538 HST 4WD (Drive shaft) #4
It does seem there is a spun a drive shaft gear. Rattling in the front can also be caused by broken ring tooth gearing but you’d have front drive propulsion. The noise goes away when engaged because you have no gear tooth connection.
   / Mahindra 2538 HST 4WD (Drive shaft) #5
From how l read the shop manual, it states “non serviceable”. This means the entire ring and pinion gear set is replaced as a unit.
2002 Sterling Bucket Truck (A50323)
2002 Sterling...
2003 Pierce Fire Truck (A50323)
2003 Pierce Fire...
Mini Forks (A50322)
Mini Forks (A50322)
Killbros 260 Seed Conveyor (A52128)
Killbros 260 Seed...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
