Insulated Roof Panels for Patio Question
   / Insulated Roof Panels for Patio Question #1
geteh
just looking
Hi all,
I’m looking to install insulated roof panels for my patio to improve comfort and energy efficiency.
My goal is to keep the space cooler in the summer and warmer in the winter while reducing noise from rain.
I’m considering options like foam core or composite panels, but I’m unsure which would be best for durability and insulation.
Does anyone have experience with different types of insulated roof panels?
What are the pros and cons? Any tips on installation or specific products to look into would be greatly appreciated.
Hi all,
Does anyone have experience with different types of insulated roof panels for patio?
Thanks in advance for any help
   / Insulated Roof Panels for Patio Question #3
Any photos of the space?
Are you thinking a standalone roof? Attached to the home?
Here is a nearby example ; 25' high, roof slopes matching the house to cover a patio and outdoor BBQ area. The roof is 2x6 tongue and groove plus insulation;
Note the wrap around screen and wind protection.
No idea the cost.
All the best,
Peter
No idea the cost.
All the best,
wedding videography brisbane
Peter
thank you so much for your suggestion
   / Insulated Roof Panels for Patio Question #5
Does your patio have walls? I'm not sure what the insulation is going to do if there isn't a way to keep the outside air from getting in there?
On my patio, I put OSB down, then 30 pound tar paper, and they metal R panels on top of that. The OSB under the metal stops almost all of the noise from the rain
   / Insulated Roof Panels for Patio Question #6
I think it would help more than a little to insulate the roof. I don't yet have my shop wired so there is no insulation or interior finishing with a duroid roof and plywood roof sheathing. While working in there during the hot weather I checked temperatures with an inexpensive laser thermometer and got readings of 55 degrees Celsius or 131 degrees F on the underside of the roof. It felt much cooler outside. This is in a 30x44 building with 15' ceiling and 14x16 door wide open. Yes there were walls to contain the heat but you could feel it by late morning.
   / Insulated Roof Panels for Patio Question #7
I had insulated panels installed on my patio and carport cover about 15 years ago. These are 4" thick foam panels sandwiched between aluminum sheets. They are sturdy enough to jump up and down on them without any flexing and they have been through several hurricanes with no damage at all. If the sun is beating down on them on a 100 degree day, the bottom of these panels is cool as a cucumber. I am very satisfied with these panels and am glad I did not get cheaper R-panels that you can not even walk on without denting them.
   / Insulated Roof Panels for Patio Question #8
I had insulated panels installed on my patio and carport cover about 15 years ago. These are 4" thick foam panels sandwiched between aluminum sheets. They are sturdy enough to jump up and down on them without any flexing and they have been through several hurricanes with no damage at all. If the sun is beating down on them on a 100 degree day, the bottom of these panels is cool as a cucumber. I am very satisfied with these panels and am glad I did not get cheaper R-panels that you can not even walk on without denting them.View attachment 2131986
Thanks! What does the top side consist of for your carport? I.e. are these the roof, or is there a truss and beam above them and under a roof?
All the best,
Peter
   / Insulated Roof Panels for Patio Question #9
All the best,
Peter
The top is just the flat side of the aluminum covered foam panel. All the support is underneath as shown in the photo. I repeat, these panels are very strong and can easily support 2 or 3 people walking on them. These panels are 4' wide and 18' long
I think it would help more than a little to insulate the roof. I don't yet have my shop wired so there is no insulation or interior finishing with a duroid roof and plywood roof sheathing. While working in there during the hot weather I checked temperatures with an inexpensive laser thermometer and got readings of 55 degrees Celsius or 131 degrees F on the underside of the roof. It felt much cooler outside. This is in a 30x44 building with 15' ceiling and 14x16 door wide open. Yes there were walls to contain the heat but you could feel it by late morning. I had insulated panels installed on my patio and carport cover about 15 years ago. These are 4" thick foam panels sandwiched between aluminum sheets. They are sturdy enough to jump up and down on them without any flexing and they have been through several hurricanes with no damage at all. If the sun is beating down on them on a 100 degree day, the bottom of these panels is cool as a cucumber. I am very satisfied with these panels and am glad I did not get cheaper R-panels that you can not even walk on without denting them. https://fmappdownload.com/
also thank you for your suggestion
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
5ft Serrated Hydraulic Dozer Blade Skid Steer Attachment (A55851)
5ft Serrated...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A55301)
Heavy-Duty...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
2013 Ram 1500 Crew Cab Pickup Truck (A55852)
2013 Ram 1500 Crew...
2020 Kubota SVL75-2 Compact Track Loader (A55314)
2020 Kubota...
