How does sawdust get into a sealed electric motor?
   / How does sawdust get into a sealed electric motor? #1
90cummins
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
Picked up an old used motor to upgrade my Delta Unisaw from 1.5 to 3hp 208 3 phase.
The bearings sounded a bit noisy so I pulled it apart to give it a little pm.
I was surprised to see how much saw dust was in there being a sealed externally fan cooled motor.
I blew it out & removed the bearings & pulled the seals & gave them a good cleaning then re-greased & assembled and tested.
Can’t wait to install it with my power feed attached & do some ripping.View attachment IMG_0625.jpeg
   / How does sawdust get into a sealed electric motor? #3
I would say that motor has been in a commercial operation for many years.
I'm still surprised at the amount, maybe it's dust resistant instead of dust proof.
No doubt it’s old perhaps 60 plus years old!
   / How does sawdust get into a sealed electric motor? #5
Perhaps it got in the same way smoke gets out???
I like that as an answer! Air leaks as the seal has been lost due to vibration after years of service.
When the motor starts up it creates positive pressure and the rotating magnetic field expands enough to attract particles near the motor.
The particles then enter the motor due to negative pressure (suction) somewhere on the housing.
Sawdust in the right concentrations can be explosive with just a spark. Don't ask me how I know, and I was trained and forwarned.
   / How does sawdust get into a sealed electric motor? #6
Very dirty! Might have come in through your junction box and where the stator wires pass through the motor housing.
   / How does sawdust get into a sealed electric motor? #7
Like @DarkBlack I'd bet it came through the junction box.
As it is an induction motor, it is only going to possibly going to arc/spark when the windings fail, but I do think @MAX-24-Dean makes a great point about why it is worth cleaning the housing out and improving the sealing. I've seen the results of motor induced explosions and the results certainly make an impression. :eek: I would replace the felt seals on the shaft (just a guess. Many older motors had them. Did it have any / is there room for them?), sealing it up with some sealant when you reassemble the housing, and I would switch to water/dust tight cable glands / clamps.
Let us know how the saw is after the overhaul!
All the best,
Peter
I removed the saw table top to make the motor swap easier and I found the s/n. According to the s/n the saw was built in 1953 which makes it 73 years old!
The mechanisms for blade raising & tilt were in excellent condition. The original motor with 4 brushes was very clean inside and the brushes showed little to no wear and zero wear on commutators.
This saw came out of a college many years ago so it may be all orginal. When I inspected the brushes I noticed the brush holder had index marks for timing purposes I’m guessing.
Ordered new belts because this motor runs at 3500 rpm with a smaller pulley.
Getting closer to the finish line.
According to the s/n this saw was manufactured in 1953 which makes it 73 years old.
   / How does sawdust get into a sealed electric motor? #10
My math comes up with 71 years. 72 if I change it to after new years 2025. Old , either way 🤔😀
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52128)
John Deere 6105E...
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
Case SR240 Skid Steer Loader (A50514)
Case SR240 Skid...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2000 JOHN DEERE 310SE BACKHOE (A51242)
2000 JOHN DEERE...
