M Martin prc60 wheel frame bent
   / M Martin prc60 wheel frame bent #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
Wheel frame bent and I don’t even know how or when it happened. Bent it rather straight but I think I will brace it.
   / M Martin prc60 wheel frame bent #2
Why post this twice??
I think it would be best to keep your original thread going and not clutter the forums with duplicate posts. Your thread states the problem, then states your solution, not sure if any of us can help if you already found the solution. Am I missing something?
Didn’ think the first post went through so I posted it again.
   / M Martin prc60 wheel frame bent #4
We Sir how can we help?
   / M Martin prc60 wheel frame bent #5
Pretty common occurrence when you aren't watching where the tail wheel is in relationship to where you are going, especially when reversing. Be more cognizant in the future. Far as bracing it, I'd like to see what you come up with....
   / M Martin prc60 wheel frame bent #6
I would be tempted to straighten it and leave it as is. It may act like a fuse, if that breaks it's an easy fix, further up the mower you start getting a bit harder.
  • Good Post
Reactions: JJT
I think you are right. I straighten it and didn’t brace it. I’m being more careful. No further problems.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
5TH WHEEL PLATE (A58216)
5TH WHEEL PLATE...
Quick Coupler Plate Loader Attachment (A56857)
Quick Coupler...
RING 2 STARTS HERE @ 9:15 AM (A58376)
RING 2 STARTS HERE...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
2014 BIG TEX (A58216)
