CK27 smoke
/ CK27 smoke #1
86Scotty
2010 Kioti CK27
New-to-me Kioti CK27 with just over 600 hours. This is my first tractor but I'm not at all new to engines or diesels, most of my diesel ownership has been with newer commercial and personal vehicles.
I recently bought and fully serviced the tractor with Rotella T4. I also flushed and filled coolant which looked fine and wasn't low. I do know the oil and fluids were several years old but don't know the hours. I get light smoke on startup most days for a minute or so but yesterday I had the first occasion to run down the road a couple miles to pick something up. Literally a couple of miles each way running in high range 4th gear, which is topped out for this tractor. I wasn't pushing it or in a hurry but was near 2k RPM's and noticed some pretty significant smoke after a bit. More when I slowed down and then it cleared.
On my return trip I backed off the revs a little and stayed below 2000 but had fairly steady light smoke. When I returned home I used the tractor on and off for the rest of the day just moving around my property, no heavy work.
Does this mean trouble? Was I possibly just running too high RPM's? Could it have just needed to be run hard and blown out a bit?
Oil and coolant level are normal and temp guage always stays at the normal mark on the low side.
/ CK27 smoke #2
Roading puts more of a load on a tractor than people realize. I suspect blowing smoke under load is just how you're tractor is going to be... like most mechanically injected diesels.
There are some experts here on TBN that can discuss injectors and injection pump issues, but that is outside of my wheelhouse.
/ CK27 smoke
I hope you are correct. I honestly have no idea what high RPM's would be for this engine either. The tach goes to what, 3500? and it has no markers.
/ CK27 smoke #4
According to TractorData, the CK27 has a rated rpm of 2600.
/ CK27 smoke
Thank you, I hadn't thought to look at TractorData for that. In fact since I bought my tractor and stopped shopping I haven't looked at any specs on there. I don't think this little guy would rev to 2600 if you wanted it to.
/ CK27 smoke #7
I put 3,000 hrs. on a CK27 usually ran it 2,000 rpm or more if roading 22 to 2600 . If there was smoke I wouldn't concerned myself .
/ CK27 smoke #8
Hey Scotty, it would be good to put a load on that engine, like bush hogging or similar for a few hours. Helps to clean out the carbon buildup if any. These small tractors usually just putt around. Not really good for a diesel to run it like that. Add a cetane boost and fuel cleaner/lube to the fuel and see if that helps some. You don’t say what oil viscosity you changed it to…but next time go to a synthetic 10w30 or 5w40 diesel rated of course, if that’s suitable for your location. No need to go heavier in my opinion. I’m running a synthetic 5w30 diesel oil in my CK30 and no smoke after 2seconds on an initial cold start
/ CK27 smoke #9
So, you changed to oil and the coolant but did you bother to check the air filter and / or renew it? Curious minds what the know and your choice of T4 is also suspect. Should have used T5 instead.
No imposed load smoking is indicative of a restricted intake system. Diesels all smoke when under an imposed load, at least pre 4 diesels do. Post 4 engines don't smoke because the smoke is consumed in the catalytic reduction medium and then needs to be 'regened', converting the soot captured into ash. Both my turbocharged tractors emit a little smoke (black) under imposed load, btw.
/ CK27 smoke #10
A CK27 with no marking on the tach? My CK27 has a red dot to show when the PTO will be turning at 540.
I have never run it above that point.
/ CK27 smoke
Smoke colour?
The colour can tell you much.
What do smoke colours mean?
Sorry, blueish smoke. Good old oil burning kind of smoke, and smell.
Of course, I didn't mention all the service but I did almost a full service. Engine oil and filter, air filter, coolant flush, fuel filter, hydraulic filter (fluid is totally clear and was full), full grease on chassis and loader, bought gear oil for front axle but didn't swap that yet. Waiting on a warmer day to finish. I used Rotella T4 15/40, which I've used in my heavy diesels for years. I run T6 on occasion but got what Walmart had two jugs of, which was T4 that day. I have not seen Rotella T5 at any store in Tennessee ever.
Air filter and fuel filter were filthy. Oil was black but full. Coolant was full.
Yes, it has markings, just doesn't have a redline that I've noticed. I have not bought or used any PTO implements yet, just the loader, so honestly before this run on the road I haven't looked at the tach much.
/ CK27 smoke
Now that I've seen some smoke I will definitely change to T6 next oil change but I really didn't think it mattered on an old small basic pre-emissions diesel tractor. Thats kind of why I posted this. Not sure what normal is for these yet. I generally run semi-synthetic, usually Rural King's house brand, in my emissions diesels. We just moved to this property and don't have Rural King closeby. In fact, not much at all is close by.
/ CK27 smoke #14
"Sorry, blueish smoke. Good old oil burning kind of smoke, and smell."
Engine oil is getting past one or more of those piston rings and/or valve seals. Might be able to play with oil viscosity to see if it makes any difference?
600 hrs on a diesel is not really very much, however if it had been abused in the past with questionable oil and/or very long change intervals, or dust thru the poor air filter.....damage has occurred.........for many people regular maintenance is a low priority.
Now that you have changed the oil keep a close eye on the level and try to get a handle on how much it is using. A small amount you can deal with (other than breathing it in when the breeze is towards you).
Unfortunately, once an engine starts burning oil it is a one-way street.
/ CK27 smoke #15
Like mentioned above, 600 hours isn’t much, unless the tractor has never had any maintenance. You never know, but maybe the oil/filter was still factory fill…but I doubt it. I’d put it to some hours of steady hard work. A PTO generator or similar would be awesome. Change the oil at 25 hours and then go for a light synthetic diesel rated engine oil, and work it hard again. I’m hoping for you that it’s just a fouled/carboned up combustion chamber…🤞
Another idea could be diesel fuel in the tank that got a qt or two of used engine oil dumped into it, simply for disposal. Lotsa unknowns
/ CK27 smoke
The oil was not the original. Both oil and hydro filter were marked April 2015. That is not good news, generally speaking, but it doesn't really mean a lot if I don't know how many hours ago that was so I didn't bother sharing.
I'm working with it actively today and putting some pretty good load on my FEL moving brush piles. Very little smoke, just when I really give it the beans.
/ CK27 smoke
Thanks guys, I appreciate the help. I'll be working this little tractor a lot over the holidays moving 8' tree sections out of the woods clearing Helene damage. I'm betting more than anything it just needs to be run and worked a bit. There is a lot of evidence, other than the old dates on the filters, that this tractor sat and sat outdoors. Unfortunately I bought it from a guy who flips them. He is solid but he doesn't have the history of the tractor and I risked that to get a decent deal on one I could afford.
/ CK27 smoke #20
Law of used tractor purchasing: Risk tolerance in used tractor purchases is inversely proportional to ones bank balance.
I had a friend who purchased (cheap) a beauty JD 4WD Utility/FEL that had ~1100 hrs and was completely clean and shiny (nicely stream washed) everywhere......only to find out the FEL would operate for about 5hrs. Changed out the hydraulic filter and it would work again for about 5 more hours.
Changed the hydraulic filter again ......only this time dissected the old one to find it full (packed) with metal shavings.
Ya, great looking green 4wd utility tractor, but required a major overhaul $$$$$$ to be useful!
Been there, seen that happen.
Hope you have better luck.
48ft. T/A Flatbed Trailer (A61568)
48ft. T/A Flatbed...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
2025 SDLANCH SDLC2020 High End Carport (A60352)
2025 SDLANCH...
2022 Iron Bull 7' x 20' Trailer (A62177)
2022 Iron Bull 7'...
2021 CATERPILLAR 303.5E2CR EXCAVATOR (A62129)
2021 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
