WinterDeere
Super Star Member
- Joined
- Sep 6, 2011
- Messages
- 13,268
- Location
- Rural 'burbs, north of Philly
- Tractor
- John Deere 3033R, 855 MFWD, 757 ZTrak; IH Cub Cadet 123
Simple problem of a BeCu (eg. C17300) or aluminum (6061-T6) dowel pin pressed into a blind hole in an aluminum (6061-T6) block: how will the fit or withdrawal force change with temperature?
This part will be carrying a reasonably high current density, and so maintaining a tight fit is important to avoid excessive heating and oxidation... which begets more heating and more oxidation, runaway scenario.
It's relatively easy to calculate the change in diameter of the pin and the hole with temperature, but what is less obvious to me is how temperature cycling will affect the fit over time. If the interference increases with temperature, is there a probability the parts could become loose upon cooling?
We normally knurl such parts, and have never had trouble, but in this case the pin diameter is only Ø.020. That may be too small to reliably knurl, or at least with any reasonable control over how far we're raising the material. We can have these pins made to ±.0003" for just a few dollars each in low volume, which should be tight enough for a reasonably-controlled interference fit, at least by the uneducated rules of thumb always used by this EE.
Temperatures are not extreme in this case, something like 0 to 120°C, and probably nearly uniform between pin and part into which it is pressed. All parts will receive hexavalent-free chromium conversion coating, which I know is not sufficient for passing salt-spray tests much above 70°C, but has always worked well enough in our non-corrosive environments at these temperatures.
