Forks
/ Forks #21
Check with the manufacturer for sizing and capacity. A lift chart will tell you how much you can lift and at what extension from your equipment. Remember the further away the less lifting ability regardless of horsepower. You may have the power to lift but not the counterweight necessary to do it safely
/ Forks #22
I will likely get longer Forks. I will keep weight in mind. I dont have to lift much weight. All the brush, or 98% anyway, is cedar. Not too heavy when dry. Just gotta haul them to a burn pile.
Thanks again. Im looking at tractor supply. Also iron something, formerly Titan, I think. Maybe something used.
As a welder all my life and worked in a shop for 3 years that made attachments whatvi would dois buy 42 inch forks for pallet moving and then make a set of folk extensions for the lighter stuff. Say for example your forks arec4 inches wide. But real heavy 6 inch C channel . Not the standard weight and make them no longer that 6 feet. Inbthe back of the channel make a loop out of 1/2 by 1 flat bar. It has a slight bend down and what you do is slide the extension on at about a 45 degree angle. When that loop gets behind the fork you can lay it down on the folk. This stops it from sliding off and quick and easy to install with no tools. Now you have the best of both worlds when you need them
/ Forks #23
Wow should have proof read that. Sorry
/ Forks #25
I have the Titan forks. 42" I think. Nice backrest on them. I use them all the time. It's astonishing just how quickly load capacity decreases as you move out to the end of the forks.
  • Good Post
Reactions: MJZ
/ Forks #26
I have 4 foot forks.
When I first got them, I tried moving some pine trees to the burn pile with them, but it's almost impossible to get the balance just right. I have a grapple, and it's the ideal tool for moving trees, but since I had the forks already on, I tried using them. It was so frustrating that I will never do that again.
I was surprised to read that, as that is something I do all the time with my pallet forks and its no big deal to do at all.
I bet I've moved brush and logs a thousand times with my pallet forks, I just move the forks as far apart as they will go and drive under the load.
Most sawmills use pallet forks or pallet forks with a matching grapple, just as I do all the time around here. I switched from a dedicated grapple to my pallet forks.
SR
/ Forks #27
In my old shop. I installed 2 x 8s on wall behind the pallet areas that were used often and that kept from poking holes in the wall.
/ Forks #28
SR
Same here. That's how I load logs on my trailer actually. Never had any issues even on hills and weird shaped ground.
I also move branches with the forks and never had a grapple or a need for one.
/ Forks #29
My forks are on a SSQA frame and are standard Class 2 pattern 42-inch length. I also have a second pair of 36-inch forks. One thing to consider is how much the forks themselves weigh. You need to adjust the width of the forks, and this involves picking them up and moving them around on the frame.
Also, standard pattern frames and forks, allow you to add a second pair of forks and use them to pick up brush piles, etc. I have a grapple on the frame, so it works well with two pair of forks mounted to use it for picking up brush piles, stacked logs, lumber, etc.
Also, the vast majority of pallets are 42X48. Even if the load is a bit off center on the pallet, you can lift it safely with 42-inch forks.
/ Forks #30
Check out goodworkstractor. They have A sale going on now, the Versa fork is quite versatile.
  • Good Post
Reactions: MJZ
/ Forks #31
I use bucket forks as I have a tractor with a pinned on bucket.
I think they are fine if you have a heavy duty bucket. I wouldn't use them with a light duty bucket.
I think a key for length is that they are long enough that you can see the ends of them when seated. Otherwise you are just stabbing in the dark.
/ Forks #32
SR
Moving cut logs with forks probably would of worked a lot better then an entire tree with the stump still attached. Something about driving across a field, and keeping it on a set of pallet forks, was just more then I was capable of doing.
/ Forks #33
When organizing pallets, forks longer than the pallet can cause problems. Holes poked in buildings, damage a pallet behind the one you are moving. A receiver is VERY handy.
Yup. "Out of sight, out of mind" almost resulted in holes in my new barn. Fortunately I got off the tractor and looked when first loading up my pallet racks.
/ Forks #34
Yep I have to be very careful with these 6 footers:
unless they are going in the long way:
/ Forks #35
I would suggest buying the size forks for what you use it for -most of the time- then get the fork extensions for the rest. They're easy to get on and off. Driving around with 5' or 6' forks all the time can be a bear.
You do NOT want to bend one of the forks, it sucks trying to pickup a pallet or anything flat off the ground.
Like it's been mentioned before, you lose almost 3/4 of your lifting capacity at the end of your forks. The "crane" guys at the Navy shipyard I worked at had a formula of how far over or near tip of the load they picked up with the forks had to be and how long the forks had to be. After 40+ years as a freight hauler I kind of giggled at how we were SUPPOSED to to it.
Hint:
Spray some bright paint on the tip of the forks and at the base of the forks so you know where the tips are and how far you can slid into the shorter pallets so your forks don't poke into things. Or if your taking a bunch of shorter pallets off a trailer just throw a board at the base of the forks and then you can go by "feel".
For me, I ended up buying just the rack, I think it was rated at 3 or 4k and put my 48" forks off my old Hyster forklift on it. My tractor probably has half the lifting capacity but I do tend to abu... I mean use it to the fullest usage possible sometimes so I usually buy a little heavier items for the "durability". The weight difference between the lighter ones and mine wasn't much of a difference and I wanted something to last awhile if I..um... over used it.
  • Good Post
Reactions: MJZ
/ Forks #36
I've got 48" forks. My primary use is probably moving brush piles, and 48" is a great length for that - wouldn't want shorter.
48" definitely sticks out behind most pallets so you've got to pay attention - and they really swing wide when you make turns. Drive carefully.
I think 48" tines are just about 100# each, 42" are about 90# each, 36" about 80# each. As you can see, length isn't going to affect your lifting capacity much, unless you try to put a heavy weight at the end of the 48".
Personally I like the 48", though I can imagine buying some 42" tines for careful movement of tote cages full of heavy wood.
/ Forks #37
I bought a light duty set of forks for my tractor rated at 3000lbs. My tractor has a loader capacity of only about 1200lbs. I did manage to bend one of the forks when a (too heavy) log rolled and was just on one fork. Keep that in mind when considering fork capacity. I also primarily use mine to move logs and brush and I got the 48" ones and I wouldn't want them any shorter.
  • Good Post
Reactions: MJZ
/ Forks #38
I bought a pair from VEVOR, I think. Bolt on, but cheap crap. Threads stripped out quickly. They sent me my money back, minus $25, and I get to keep the forks. (I see a project coming my way)
I bought another pair from Titan, I think. Much better construction, I can crank them down without issue. I can (try to) lift as much as I can, and no smiles on bucket. But then again, my bucket seems to be thicker and of better construction than the JD and Kabota ones in same class tractor.
  • Good Post
Reactions: MJZ
/ Forks #39
Forks don't need to be super long. My forks are 42 long. I can move brush and logs just fine. I have 8 acres of wood and our house is centrally located in the middle. We have a fireplace so im cutting wood often. Basically I cut up fallen trees into 8 to 10ft long. I take them to my stoned staging area. Where I will then use my forks to pick up the logs and put them on my elevated log holder. At this time I cut them into rounds. Once I get so many piled up and then use the buck to scoop rounds and take to the splitter. I have the bucket about waist high so its very simple to go from bucket to splitter.
When it comes to moving brush. Forks do a good job. Is a grapple nice to use. Sure but is it necessary. No. Skill of operator plays a big role into what a machine can do. Ive been around equipment all my life. I run a 352 excavator for work which is a big machine. Ive ran bigger. Plus farming. So an experienced operator can make tasks look very easy. For instance I have neighbor who bought a tractor a year or two ago. He's still got a long ways to go before he becomes proficient.
/ Forks
Thanks. I think I will go with 48 in h forks. 99 percent of brush is cedar. Nothing huge. Up to 10 inch or so at base. I too cut a lot of firewood. I just have to walk it out of the woods. I typically cut the rounds and put in bucket or truck bed. We will see how else I use the forks. I've already strapped a couple things to the bucket. Forks will be handy.
2023 Caterpillar 289D3 Skid Steer (A64047)
2023 Caterpillar...
2021 PETERBILT 367 (A63569)
2021 PETERBILT 367...
2014 PETERBILT 384 TANDEM AXLE CDL REQUIRED WRECKER (A59575)
2014 PETERBILT 384...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
