Heat Tape- 120V or 240V to prevent ice accumulation?
   / Heat Tape- 120V or 240V to prevent ice accumulation? #1
plowhog
Elite Member
North. NV, North. CA
Massey 1710 / 1758, Ventrac 4500Y / TD9
Ice sliding off the roof of my metal garage damages the gutter every year. I want to prevent this in the future.
The building is insulated, but the overhanging eave is not. It's the roof area above this eave where I accumulate ice, which is within 3 feet of the gutter. Farther up the roof is not so much of a problem. My roofer can install heat tape in a WWWW pattern to protect this area.
Platt Electric has Raychem heat tape in both 120V or 240V versions. The 240V version is $23/ft vs 120V version at $7/ft. Some versions are limited on total distance but I could split the total run into two separate runs that meet in the middle. Total footage is going to be about 280 feet after all the patterns in a W fashion are done.
Q- does anyone have experience with the pros and cons of 120V vs 240V? I have to run special electrical outlets anyway, so the added cost for heavier wire for 240V won't be that much. It's the heat tape itself that is much more expensive in 240V-- about $2,000 for 120V vs $6,000 for 240V.
Ideas?
   / Heat Tape- 120V or 240V to prevent ice accumulation? #2
I think the reason for the 2 voltages are, in Europe it's 240. Get the 120, you'll be fine.
   / Heat Tape- 120V or 240V to prevent ice accumulation? #3
With the amount of money you're considering spending on heat tape, you may be able to fix the problem. Heat tape is a bandaid fix. What is the roof pitch?
   / Heat Tape- 120V or 240V to prevent ice accumulation? #4
Im an electrician and have installed lots of heat tape. There are 3 differences in raychem tape. First is wattage per foot, second is total length, and finally is it self regulated or not.
The first one you listed, which i pay about $6/ft, is self regulating and is 6 watts per ft.. max 250’ per circuit
The second one you listed, which i pay about $11/ft and its self regulating. But its meant for use inside pipes, grease traps, etc. not meant for gutters.
Platt also sells a 6 watt per foot, 240 v heat tape for about $7/foot. Up to 400 ft run per circuit. This is meant for gutters.
You need to run it like a bunch of WWW and run a length thru the gutter and thru downspout
You also need a special type of personal gfci rated 30ma GFCI breaker. This allows a higher trip rating than standard gfci
   / Heat Tape- 120V or 240V to prevent ice accumulation? #5
Self regulating tape is more expensive to purchase, but saves $$$$ over time cause it basically shuts the section that doesnt need to melt snow while powering areas that do need to melt snow.
That is very interesting, thank you.
Also did not know about a special GFCI device. The roof pitch is 4:12.
   / Heat Tape- 120V or 240V to prevent ice accumulation? #7
I generally use winterguard wet.
Very helpful, thanks. I have a downspout on each end of the gutter, giving me the option to do two 120V runs, one up each downspout meeting in the center. If 120v need to split it up due to limits on total footage run.
My installer recommends looping the bottom of the "W" pattern down into the gutter to prevent gutter ice. But, it looks like Raychem recommends running a single additional straight piece which lays in the gutter. That would add a 3rd circuit if one is dedicated inside the gutter only.
Q- have you typically run the additional straight piece in the gutter, or just let the bottom "tails" from the W pattern go into the gutter?
   / Heat Tape- 120V or 240V to prevent ice accumulation? #10
I loop the tails into the gutter and run a piece in the gutter and down the downspout. Ill take a picture and post later. I almost always use 240v tape myself, as its only about $1 a foot more than the 120, and im not screwed up using more length than i thought i would need.
1701 (A58375)
1701 (A58375)
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2313 (A58376)
2313 (A58376)
2219 (A58376)
2219 (A58376)
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
Heavy Duty Skid Steer Breaker (New/Unused)(Est. Retail Value $4,800). (A59225)
Heavy Duty Skid...
