   / Share Pics of People Hauling or Towing Something Wrong #21,542
   / Share Pics of People Hauling or Towing Something Wrong #21,544
I guess it's empty, otherwise it may've lifted the truck - I think more than half of it is behind the axles midpoint.
Or there is a heavy load in the front half. At work we would need a jack under the 5th wheel if trailers were parked at the loading dock. A heavy load (like a pallet of steel) and forklift in the front could tip the trailer.
   / Share Pics of People Hauling or Towing Something Wrong #21,545
I think if there was a heavy load in the front half, the front half would actually be on the trailer instead of lifting up off of it in favor of the rear half - or is there some hardware under it up there?
   / Share Pics of People Hauling or Towing Something Wrong #21,546
Huh, your right, if there's a load in there, how dey do dat. Ok, skip that.
   / Share Pics of People Hauling or Towing Something Wrong #21,547
It looks like an old semi trailer, minus the axles, sitting on the trailer backwards. It's probably not 'lifting off' as much as there is a part of the rear bumper under the box that keeps it from being flush with the trailer. Note the straps on the front half of the load... There's no reason they wouldn't be cinching it all the way down to the trailer if there wasn't something under the box keeping it lifted.
   / Share Pics of People Hauling or Towing Something Wrong #21,549
I sure hope he has a RED FLAG on the back of that load.. lol
   / Share Pics of People Hauling or Towing Something Wrong #21,550
Set of heavy car rolling dollies used under the trailer's landing gear/legs. Cable or chain around fifth wheel pin to fork lift pulling in the building, or something pushing it against the trailer rear bumper. Front nose of trailer cut out to load trailer. I think this is a permanent long term solution, no license plate on the trailer. Jon
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
2020 Komatsu D155AX-8 Crawler Dozer, S/N 100205, PIN# KMT0D126PJC100205, Turbo Diesel Engine, 13' (A59076)
2020 Komatsu...
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
2011 GALYEAN 130 BBL VACUUM TRAILER (A58214)
2011 GALYEAN 130...
