You ever know how bad a wind storm will be in Oregon.
   / You ever know how bad a wind storm will be in Oregon. #1
JasperFrank
Ford 1220
Its up today. And don't know if a microbust will happen. Everything is put away and secured. Get getting for the power to go out and get the wood stove up.
   / You ever know how bad a wind storm will be in Oregon. #4
I watch this guy on u tube. I think he does a great job of explaining what weather is coming in the Pacific North West. He also has a California channel.
   / You ever know how bad a wind storm will be in Oregon. #5
When I first came to New England as a young man "from the Dakotas", I came to be friends with an old fellow in north New Hampshire by the name of George Tucker. He had in his yard every sort of construction equipment one could imagine, including a stone crushing mill and a logging skidder fitted with a back hoe. (that didn't steer well) .
Any way, when I revealed to him that I was originally from the Dakotas, he smiled and said to me, "you must appreciate it here, being out of the wind and all"
I agreed that I had noted that very aspect.
It was breezy and warm here today. One of the tractor covers slipped out from under it's ropes. The wind died with the setting sun, like it always does. I'll reset the cover tomorrow.
It was a great day for drying the ricked up firewood/
   / You ever know how bad a wind storm will be in Oregon. #6
Today was not so windy, but the previous two days were gusting to over 40mph most of the day and night.
Cheers,
Mike
   / You ever know how bad a wind storm will be in Oregon. #7
I can get wind here - any time of the year. The very strongest - around 40 mph. I have a semi-circle of large Ponderosa pines that shield the house and out buildings. Anything above 35 mph can get pretty loud. I've never had any wind damage. Knock on wood.
   / You ever know how bad a wind storm will be in Oregon. #8
Yeah, what we consider a major windstorm would be a light breeze in some parts of the country.
We're on the SE side of a mountain ridge, so we're protected from most of what does come thru. The downside is that from about now 'til mid-Feb. we have only a few hours of sunlight per day as it doesn't get much above that ridge this time of year.
   / You ever know how bad a wind storm will be in Oregon. #9
I'm a little confused here. I understand the wind protection from a ridge, but wouldn't being on the southern side of a mountain ridge maximize your sunlight, unlike being on the northern (south facing) side of a ridge? Are there other ridges to the south that also block sunlight.
All the best,
Peter
   / You ever know how bad a wind storm will be in Oregon. #10
The sun is so low in the sky this time of year that it barely clears the ridge. Only sun we get in the winter is fairly early in the morning. If the house was even a couple hundred yards to the east it'd be an improvement.
Then again, that whole ridge was probably totally clearcut in the 1830s when this house was built, it's totally forested now.
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
Aluma 7712H Tilt Trailer (A50514)
Aluma 7712H Tilt...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
Bron V75-3 Pull-Behind Hydraulic Vibratory Utility Plow (A49461)
Bron V75-3...
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
