   / Share Pics of People Hauling or Towing Something Wrong #21,521
   / Share Pics of People Hauling or Towing Something Wrong #21,522
Here. Hopefully you have a better day now?
General question, tandem trailering and trash bag windows aside: Trailers over 3000 lb. require brakes in PA, and I suspect most states have similar limits. So how are these types of car haulers ever legal?
It appears most states require brakes on only one axle of the trailer, such that the towing dolly could be outfitted with brakes to make it legal. But in some states, including Pennsylvania, brakes are required on all axles of any trailer over 3000 lb. That doesn't seem possible with this type of rig.
   / Share Pics of People Hauling or Towing Something Wrong #21,523
I guess no different than "flat towing" the vehicle with no brakes on the towed load. Not saying that's particularly safe either.
   / Share Pics of People Hauling or Towing Something Wrong #21,524
Surge brakes on the dollys? Zooming in it looks like they are.
   / Share Pics of People Hauling or Towing Something Wrong #21,525
Surge brakes on the dollys? Zooming in it looks like the are.
I think that in states requiring brakes on all wheels, even this is not legal. Doing a quick little read on flat towing threads on a camping/RV forum, it seems that auxiliary braking systems on the flat-towed vehicle are mandatory in at least some states.
   / Share Pics of People Hauling or Towing Something Wrong #21,526
Does flat towing (like behind big RVs) require active brakes in the towed vehicle. I see eTrailer advertizes them. Just wondering? Jon
Looks like WG also matched my comment. Jon
   / Share Pics of People Hauling or Towing Something Wrong #21,527
Based on comments above, I believe that most of you misread the photo in question. The pickup is towing one vehicle while pushing another. Perfectly safe, as long as he knows what he is doing. 🙄
   / Share Pics of People Hauling or Towing Something Wrong #21,528
YES, flat towing a vehicle behind a RV requires brakes I think in every state.
Trailer depending on weight also requires brakes. I think most states limit is over 1800 lbs.
   / Share Pics of People Hauling or Towing Something Wrong #21,530
That seems to depend on the weight of the towed vehicle.
I believe it's 3000 - 4000 lb. in most states, which probably includes most vehicles one might want to flat tow behind an RV. They also have to be flat-tow compatible, which often means something with a transfer case that can be put into neutral. I think this may be way you see so many Jeeps towed behind RV's, as they're smaller and lighter than pickup trucks and Suburban's, but unlike AWD Subaru's, most Jeeps still have a manual transfer case.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SCALES & PEA (A58374)
LOT OF TIN (A58374)
LOT OF TIN (A58374)
Club Car Carryall 2 Electric Utility Cart (A55853)
Club Car Carryall...
(APPROX 23) 2" X 2" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 23) 2" X...
Hose Reel (A55758)
Hose Reel (A55758)
