coolant what type
/ coolant what type #1
can do
Gold Member
Nokesville Va.
M-F1526,M-F50
What type of coolant are you using for your M-F 1526 3 cylinder Iseky diesel engine.
/ coolant what type #2
The owners manual for my new 1526 only specifies "50/50 mixture ethylene glycol and water" on page 104. I'm not there yet but I figured when the time comes I'll use a name brand (Prestone) pre-mixed ethylene glycol.
/ coolant what type
Thank You for your reply; I've never changed the coolant on my 2018 1526 even though it does call for it annually she only has 120 hrs. on the clock. I'm going to be doing a coolant change on my M-F 50 as well, & I wanted to use the same type of coolant for both tractors the M-F 50 is a gasoline tractor, & I use Peak long life coolant on her which is good for 5 years. How do like your M-f 1526? Take care ,& thanks again. IMG_20201003_134009.jpg
/ coolant what type #6
Thank You for your reply; I've never changed the coolant on my 2018 1526 even though it does call for it annually she only has 120 hrs. on the clock. I'm going to be doing a coolant change on my M-F 50 as well, & I wanted to use the same type of coolant for both tractors the M-F 50 is a gasoline tractor, & I use Peak long life coolant on her which is good for 5 years. How do like your M-f 1526? Take care ,& thanks again.View attachment 1691012
I've only got 22 hrs. on it so far but I love it. The seat switch had to be tweaked after delivery and the trans. range selector can be a little sticky but otherwise perfect. Have you had any issues with yours?
/ coolant what type
No I have not had any problems with Nadine other than the placement of the oil filter when installing a new one; I did post a thread here on how I thought was the easiest way too remove, & install it. I agree that the drive lever for snail to rabbit can be a little stiff sometimes, & the lever to engage the 4 wheel drive can be stiff as well, But overall it has done everything that I need it to do which is to work with my dump truck. What I like most about it is frees up my other tractor Stella for wood splitting , & skidding logs out of the woods. They are both work savers, & compliment each other. I'm quite happy with her.
/ coolant what type
I use 50/50 green stuff in my 1533.
I ended up buying Peak, & it's called Asian green for engines that are made in Asia; It's a 50/50 mix good for 5 years, & for the older M-F I went with a Peak 50/50 green which is also good for 5 years. I can't believe all the different coolant colors, & the different applications. Thanks for your suggestion.
Wooden Native American Totem Pole Statue (A61569)
Wooden Native...
2025 Auger Bit Skid Steer Attachment (A61567)
2025 Auger Bit...
2015 FREIGHTLINER CASCADIA 125 6X2 T/A SLEEPER TRUCK TRACTOR (A59909)
2015 FREIGHTLINER...
Hydraulic rail grinder (A61307)
Hydraulic rail...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
Gorman-Rupp T-Series Towable Pump (A61567)
Gorman-Rupp...
