My only comment is, glo plugs are for intermittent use only and all glo plug equipped engines are pre-chamber engines, designed with a smaller pre combustion chamber in the head that allows the glo plugs to heat the cold diesel fuel upon cold cranking to initiate the combustion process.  That process then allows the main combustion chamber to ignite the diesel fuel and allow the engine to start and why it 'bangs and clangs' upon initial start up as the fuel in the main combustion chamber isn't igniting 100% and why you get a puff out the exhaust pipe.  Glo plugs are for intermittent use only.  If they are on all the time, they are most likely shot and need replaced.  My Kubota's have a glo plug override under the dash panel that will limit the plug actuation to a pre set time.  I can initiate the glo plugs via a starting key detent but if for some reason I hold the key in the glo plug on position for too long, the under the dash panel override will engage and turn them off.
Even in the dead of winter up here, with a fully charged battery, I never need longer than 15 seconds of glo plug actuation to start my diesels.
If I were you. I'd install an external toggle switch to activate the glo plugs independent of whatever starting system you have and be able to turn them off as continuous operation will destroy them pretty quickly.  Like I said, they are for intermittent cold start use only.
Candidly, I've never replaced a glo plug in any of my diesel pre chamber engines, including my '97 7.3 Navistar diesel pickup truck.
One other thing to note is, your starting battery as well as all the physical connections, must be clean and corrosion free and the battery must be fully charged, especially in cold weather.  Cold temps adversely impact a starting battery's ability to provide sufficient starting amperage to turn over a cold engine with thickened lube oil and the extra amp draw on the glo plugs even compromises the starting battery's ability to provide sufficient amperage.
Batteries and corroded connections are the most overlooked items on any diesel engine.  I replace the starting batteries and brighten all the connections and apply di-electric grease to them, every 5 years, maximum or load test the batteries to determine if I need to replace them sooner.
