2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 9,611
Cheaper to do this once and be done with it with the right materials than for it to clog and not drain properly and have to be redone. Corrugated plastic pipe is flexible which makes it harder to accurately set in place so it is correctly pitched. Rigid solid wall pipe will be easier to correctly set in place, less likely to sag, and will carry more water with fewer clogs. So spend the $ and be done.
You could install multiple drain pipes if needed to achieve the capacity needed.
