SAME Mercury 85 oil leak in the bell housing
/ SAME Mercury 85 oil leak in the bell housing #1
mark in portugal
Gold Member
Portugal
same 85
This is a 1985 SAME (now SDF) 85HP Mercury 85.
I had a lot of of leaking from the starter motor (???!!), it was from the bell housing, flying around in there.
I assumed it had to be the rear main engine seal, but it turns out to be gear oil leaking through an end cap.
There's an Oring in there, it might be a special profile or maybe the old one is just deformed over time. Anyway, I ordered the part by number from the catalog, so I'll see what comes.
The seal is compressed along the face of the cover plate, but there's no provision for clamping it down, it's held in by a big circlip. It seems sort of optimistic to me.
Note; to remove the bell housing, the throwout bearings come off first. There are 4 springs behind them that have to be unhooked; easy enough, but getting them back on again is going to be great fun (not).
The FEL / ROPS frame is half resting on the dolly below. The engine is supported by the overhead hoist.
Rear main engine seal, looks good but I'll change it anyway.
I did a little test; this just took a minute and confirmed the source of the oil.
The throwout bearing assembly; I pressed it apart to change the bearings. That required a couple of jigs to be made. I'll try to get a picture.
After cleanup; the pink colored cap below the main shaft is where the leak is from. It's a cast iron disk.
I made the adjustable jackstand earlier.
/ SAME Mercury 85 oil leak in the bell housing #2
Fun times ahead Mark!
I agree with changing the rear main seal while you're at it. Kinda reminds me how I lost the brand new transmission input shaft seal on my Agria and decided to go with the old one. Guess what leaked once I started the engine? :)
Have you checked if there is any seal between the transmission input shaft and the PTO input shaft? Might be a good time to investigate that as well.
If you need any parts, there is this tractor parts shop in Aveiro, called Casa Rola. They can get pretty much anything for just about any tractor. I'm sure they can ship parts to you as needed.
Thanks, Pedro;
I looked at the parts diagram, there is no seal or oring to be seen on the outer or inner gearbox shafts. What keeps the oil from coming though is a mystery to me, but the oil level is below the shaft so I guess magic is sufficient.
I lightly pressurized the gearbox with air to check.
I asked my local shop to get the seal for me. I found it at various online shops, online it costs about 50 cents + 30 euros postage. I intend to machine a grove and add a second Oring; when I post pictures, you'll understand.
I asked him to get the throwout bearing also, just so there would be some decent markup in the deal.
I found that the throwout bearing is used on other tractors and trucks, so I could probably order it at auto parts store too. Auto-doc has it.
There is also a bearing for the PTO clutch, which is a huge standard bearing (75x130x24) because of geometry, and cost 85 euros new; I'm going to clean and repack the old one. It hardly gets spun at all, and even then the pressure against it is negligible.
/ SAME Mercury 85 oil leak in the bell housing #4
Thanks, Pedro;
I'm sure you'll have a solid solution to figure this one out.
I feel you on the throwout bearing. I can't tell you how many days I spent just researching release bearings, just about eveywhere. The one for the Agria was completely trashed and I didn't want to buy the entire assembly for 120€ when I knew I could get just the bearing for 20€. The big issue is that hardly anyone publishes the dimensions of the bearing.
Somehow I ended up on a Chinese bearing supplier that had a big catalog, so I figured what I needed and finally ended up buying one online from a store up north.
I bought all the seals from this place, even though it takes a bit for them to ship stuff. They list a lot of bearings, some with dimensions. If you want to check it out: Pesquisa: 82 resultados encontrados para "rolamento* embraiagem*"
Tractor shop says he'll have the main throwout bearing tomorrow; I didn't aske the price but he's usually reasonable and Auto-doc has them for around 40.
The big bearing for the PTO clutch is repacked and reassembled. I had to cut a pipe to press it apart, but it goes back together very easily.
Pressed it back with the "horizontal press"
Tractor guy thinks the seal must be a regular Oring that has become deformed over time; he's probably right. I should have just gone to the bearing + seal shop and bought a pile of possibilities to try.
The cap is 10mm thick, so I can cut a groove and set another Oring in there. That will make me feel better, but I also need to cut a threaded hole so I can pull the cap off again.
After reading about how you had a leak at your transmission shaft, I looked through my parts diagram again and found there is a seal in there (listed on another page), probably in the neck tube.
I'll take it apart tomorrow.
There are 2 gearbox shaft seals, one on top of the other, both the same size.
The parts book lists one of them as "special seal". A part number search brings up regular seals of that size. Anyway, I ordered 2 new (normal) ones.
There is also a seal between the inner (drive) and outer (PTO) shafts too, also listed as "special". That one is deep within, so I'm not going to go there unless it actually leaks.
And maybe not even then!
I took the triangular section Oring to the tractor shop; all agreed it looks like it was made in that shape, but that it could have been originally round.
I'd looked up the number and found that it's common to quite a few tractors. The old man of the shop said he'd never seen a triangle section Oring; and since he's the old guy and I'd found it was a common part, we all agreed therefore, there are no triangle section Orings.
I ordered 3 different thicknesses of regular round Oring to try.
It will be necessary to press the cover in with some force to compress the Oring before putting the circlip in, I'll need to rig up something for that.
/ SAME Mercury 85 oil leak in the bell housing #8
I don't think any of those shafts are actually under the oil level. Only if working on hills and the front is pointed downhill. Just guessing here. I'll say you'll be alright without messing with the seal between the two shafts.
For the rest, since those are more or less easy to change, might as well do it now and have the piece of mind.
I agree on the o-ring being round. It's most likely just deformed from being pressed all of these years.
That cap is indeed asking for an o-ring on the OD. Maybe a 2 mm section o-ring, so you don't have to cut an huge groove.
Yes, I'm thinking 2 or 3mm; I'll see what the shop has in stock. I have to wait a day or two until he gets the seals.
Luckily, there is a bearing + seal shop within driving distance, about 30km north in Odemira. The larger towns to the south don't have one anymore unless I go all the way to Faro, 100km.
I don't know how the shop in a small town like Odemira has enough business to stock as much as they do; the guy is really enthusiastic, maybe he just likes it.
The upper rotating shafts are above the oil, but the lower one with the cap is not.
I got the new throwout bearing and some seals, but I'm still waiting for the rear main engine seal.
When I unpacked the new bearing, I found the grease cover is smaller than the old one, so the spacer/ grease plate doesn't fit inside it.
That was Friday; if I return it I won't get a new one until Monday or tuesday, and it might be the same.
So I made a replacement spacer ring to solve the problem. I used a lump of flame cut plate so it took a couple of hours.
Satisfying though.
old throwout bearing;
old + new bearings and rings.
new spacer / grease ring pressed onto bearing collar
Throwout bearing assembly;
Cut a mounting groove into the iron cover, made a pullout thread and an oring groove.
the inner Oring is 5mm and the cover needs to be pressed against it with some force before the big circlip can go back. So I made the press bar from 30x30 stock I found in the workshop.
I made a test fit first, then pressed it in with the extra Oring.
The local bearing shop didn't have a big enough Circlip tool, so I bought needle nose vise grips and ground the tips down.
throwout bearing collar reinstalled with new seals, 2 of the 4 diabolical bearing return springs are on there too.
Bell housing hanging from the hoist for reinstallation.
I managed to reinstall all 4 diabolical return springs in just 1-1/2 hours. only one can be partially seen.
I should have the rear main engine seal tomorrow, so I can get it all back together.
/ SAME Mercury 85 oil leak in the bell housing #12
Excellent work Mark! That beast will be running in no time!
Those springs do look like a lot of fun indeed in that little tight area. Great job holding that thing plate on the lathe to cut the groove.
I imagine that at the factory, they hired a contortionist from the Chinese circus to install those springs.
Paid per job most likely.
Engine seal didn't get to the shop yet, maybe tomorrow; anyway, there is plenty to do.
I should check the valve clearance and retorque the heads.
Not in that order, obviously.
The rear engine seal finally turned up, so work could continue.
There's a pretty bad groove worn into the crankshaft journal, so I set the new seal on the outer edge of the housing, about 3mm out from the seat, so the new seal rides on undamaged metal.
I made an alignment tool for this tractor 6 years ago; I think I used the metal for something else. Anyway, it's quicker to make a new one than to find the old one.
The double clutch assembly is a bit heavy to lift be hand; and why should I when I put all that work into putting in the gantry hoist?
2 of the clutch bolts are stretched; can you see it? I felt it continue to stretch when torquing, so pulled them out and replaced them.
To get the halves in alignment, I needed to steer; that was done with a ratchet strap.
slowly coming together again. This is actually fairly tricky. 2 spline shafts, lots of linkages and tubes to worry about, and getting it all lined up.
A little twist on the PTO shaft to get the PTO spline into its clutch plate.
The tractor is one piece again, but there's still a lot of reconnecting to do
All reassembled; while checking the hydraulics, I found a leaky hose.
This tractor has 10 hydraulic hoses that are all the same (after my modifications), so I have a few spares in stock.
And ready to work; I have some tractoring work pending by now.
/ SAME Mercury 85 oil leak in the bell housing #16
And ready to work. Great job on the repairs Mark.
Thanks; I don't know how many hours and Euros I've put into the old beast, but it's done a lot of work for me in return.
It's only economically viable because I can do the repairs at home myself. Even at Portuguese wages, if I had to pay every time it broke, I'd be broke too!
It's it pretty good shape now, so hopefully it will go for a long time without any more major work needed...
Hopefully.
2008 CHEVROLET COBALT(INOPERABLE) (A60736)
2008 CHEVROLET...
2015 Chevrolet Caprice Sedan (A61569)
2015 Chevrolet...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
LOAD OUT AND SHIPPING (A61165)
LOAD OUT AND...
2013 GMC SIERRA (INOPERABLE) (A60736)
2013 GMC SIERRA...
1987 INGERSOLL RAND PT-125R PNEUMATIC ROLLER (A62129)
1987 INGERSOLL...
