part-time-Farmer-NC
- Joined
- Oct 7, 2024
- Messages
- 1,069
- Tractor
- Kioti DK45Se
Kinda odd, I think this has been troubling me for a few years and I didn't tie it together until recently. When I crank the DK45SE and immediately start the PTO by engaging the rocker switch. It often doesn't come on at first usually. I leave the rocker switch in the engaged position and drive it around a little bit. Sometimes the PTO comes on in about 30 seconds, sometimes it is about 3-5 minutes. Seems like the longer I go without using the PTO it takes longer to come on. After it does come on, I can turn it off and back on and it works fine.
When I say come on, I mean the rocker light turns red but the amber gear doesn't light up in the dash, and the PTO isn't spinning. Hydraulic oil is within range but towards the top line. I haven't noticed any leaks in a while (had one on the FEL for the third function I put on there about 10 yrs ago). Changed the filter and fluids about 6 months ago no change to this problem.
Another thing I noticed when it hadn't been run in about 6 weeks (couldn't get it start another story...) I could lift the bucket and down but it wouldn't tilt. I thought the hose(s) had gotten disconnected but no. I drove it around for 3-5 minutes and the bucket started working fine. Then a little later the PTO came on.
Is this a PTO pump issue maybe? Any ideas how to check that? I have called the dealer before about it not starting, they keep saying they have a 3-4 month waiting period for service work every time I call them about any work (twice).
I prefer to do these things myself if I can when I think I can anyway. I wouldn't tackle a motor rebuild or anything like that, but maybe a little more than minor repairs I have done ok with them.
Any suggestions/ideas?
New user name was tpulley and tpulley2 but those accounts won't let me back in. I posted about this a few times over the years.
