help identifying chinese excavator fitting
/ help identifying chinese excavator fitting #1
Michael In Tennessee
Gold Member
Niota, TN
Kubota MX4800HST
I'm adapting a chinese excavator smooth face tilt bucket to my Kubota BH92 backhoe. MEchanically, it actually was pretty easy. I'll document that success separately.
Now I need to adapt the tilt cylinder hoses to common Ag couplers. Attached two pics. The first is the hose end. Can't really measure much about it. The second is the cylinder fitting. The outside thread appears to be a M18x1.5. The inside, where the o-ring seats is slightly tapered. The big end is 0.545" or about 13.8mm and tapers to 0.478" or about 12mm. I need to source an adapter that goes from the hose end to probably an NPT fitting.
Of interest, the other side of the cylinder adapter is an o-ringed M14x1.5 I can find a M14x1.5 to JIC fitting, but then, I need new hoses. The JIC adapters I could find were expensive as well. I did find a pack of 10 on e-bay, but I got an e-mail from the vendor saying that the o-rings were cracked and damaged and he will refund my money. Otherwise, I was looking $35-$40 for a couple of fittings including shipping.
/ help identifying chinese excavator fitting #2
See if this video helps.
/ help identifying chinese excavator fitting #3
Have you looked into Surplus Center? They have pre made JIC hoses with choice of nominal or 1+ end connections. Also lots of adapters to choose from.
Hydraulics | www.surpluscenter.com
A little bit, but not really. It would appear that I would need an L18 to npt fitting, and while the thread size would be correct, nothing I have found yet tells me the dimensions where the 0-ring would seat. Only thing I find is how hard lines fit.
Surplus Supply is my go-to for most things. But they do not have metric fittings. If they did, they would be cheap and already on the way.
/ help identifying chinese excavator fitting #6
How bout getting the M14x1.5 - JIC and then to SC hose and dont look back?
Because I didn't like the price of the adapters and I have a hard time just tossing perfectly good (but weird connectored) hoses in the trash. If I could just adapt the hoses I have to NPT, I'd be golden.
But, your suggestion is back-up plan #1. I was finding fittings at $10 each, but $20 shipping.
/ help identifying chinese excavator fitting #8
Im not sure I have a full picture. What has the NPT?
/ help identifying chinese excavator fitting #9
I like their paper catalog, but beyond that they've gotten crazy with shipping. Yesterday I worked up a small order, 3- 3/8" hoses all #6 jic swivels and the longest one was 48". They're not known for fast order shipping, and $26 dollars shipping was more than the order. I can do better than that getting them made locally.
Summit hydraulic and discount hydraulic hose have been what I use lately, but no nice paper catalogs. 😆
/ help identifying chinese excavator fitting #10
Me too. As for shipping, I havent paid enough attention. I usually order about $100 worth or up. Maybe $26 is sort of a minimum S/H charge, and it just edges up slowly from there?
/ help identifying chinese excavator fitting #11
Per an old Aeroquip fitting handbook that fitting with O-ring could be a DIN 3902 DKO style fitting. The hand book is 24 years old so very good chance there are other variations out there now.
/ help identifying chinese excavator fitting #12
The fittings are DIN 2353. Meant to be used with hard lines, however, there are fittings that go on hoses as well. Often these fittings use an o-ring to help seal the taper.
That looks right. So, I can use my existing chinese hoses and connect to ag couplers using this fitting...
