Wiring diagrams for LS XG 3135H and others are in this thread.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #1
Grizzysdad
Grass Valley, CA
LS XG3135H
I have rodent damage on the wires running to the DPF sensor, Of course the little pissants left me about an inch of stub where the wires go into the main part of the harness, just enough to splice to. I replaced the wires, and it runs but has codes flashing, which tells me that the wire repair didn't succeed. Before I try again, I'd like to check the wires for continuity, as last time at one point it involved standing on my head and I would like to avoid that if possible, so I'm looking for a wiring diagram.
I'd appreciate it if replies were kept to wiring diagrams and not rodent avoidance, as the last time I posted this most of the answers were about getting barn cats.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #2
I can offer some manuals that I use for mine.... MT240 and Workmaster 35 manuals in one zip. Link will only active for a few days because I'm dropping that server when the bill come due again.
https://gerrysweb.com/Manuals/LS-XG3135H.zip
   / Wiring diagrams for LS XG 3135H and others are in this thread. #3
The workmaster is the LS XG/XR tractor minus a few standard features that are options on the Workmaster. NH uses a different loader (I think) and a different shade of blue. If you add MT to front of an LS part number you have the NH number.
The MT2 35 and MT2 40 is the next generation of the XG and XR 3135 and 3140
Workmaster is a re-branded LS with minor differences in options. These manuals so far have let me figure out things since I could not find an XG (or XR) service manual when needed. I bought mine used and had to learn.
Now be prepared the was an evolution in tractors nothing simple anymore. I have 2000 BX and nothing to it, like your 7800 just mechanics. These tractors are all ECU driven and just having the error codes in hand is a lifesaver. If I can help give me a shout.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #4
I hope it works out, it way better than nothing. If you guys do run into a XG service manual, remember me. :)
I've never had too much tech info.
Thanks so much Eagle1. I'll definitely forward any manual I find to you.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #6
   / Wiring diagrams for LS XG 3135H and others are in this thread. #7
   / Wiring diagrams for LS XG 3135H and others are in this thread. #8
My Hero :love: Thank you for sharing.
not a problem, i'm a firm believer in giving people who would like it the ability to do their own work, the fact some of these companies hide these behind paywalls is awful, like you guys already paid 10-40 grand your your equipment ( depending on the model) why should you have to also pay more to be able to work on it.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #9
Asteral over here doing public service! Thank you Asteral for all the help over the years!
   / Wiring diagrams for LS XG 3135H and others are in this thread. #11
Thank you!! Downloading now. I'll be sure the OP sees this too.
You guys are great!
The manual does confirm that the Workmaster 35 -40 is the same as the XG 3135 -40. I did not see the error codes in the last manual but the Workmaster manual has them.
Pretty sure I'm covered as needed. Thanks again
Thank you so much. I wish that this forum had a way to make this a sticky. I've edited the title to make this info easier to find.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #13
my pleasure ptsg
Just out of curiosity, would you happen to know where I can find a service manual for 2014 XR4046? I mainly need the wiring diagram. I think my tractor is the same as NH Boomer 47? I could be wrong tho', any pointers would be much appreciated.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #14
i believe this should be the version you need
   / Wiring diagrams for LS XG 3135H and others are in this thread. #15
Asteral: Many Many thanks, the manual you provided had wiring diagrams and now I hope to be able to figure out the glow plugs issue since I bypassed the ECU. The manual I got from the dealer had lots of information missing.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #16
No problem glad i could help
   / Wiring diagrams for LS XG 3135H and others are in this thread. #17
Thank you for the manuals, i just found this site today and hoping with a little help i can get my tractor fixed!
   / Wiring diagrams for LS XG 3135H and others are in this thread. #18
Hi, reviving this thread due to my search for info on a 2016 model LS XG3135 that I'm considering purchasing. Seller claims that the loader 'control cable is frozen up', and says it goes from the controls down to the hydraulic valve assy. Is this a 'thing' with these tractors? All the loaders I've used put the valve directly under the handle(s). He also says that it 'needs DPF regen by a dealer'. Is this something that could be accomplished with an affordable code reader/programmer, or does it demand dealer intervention? (Or, can the DPF be deleted in hardware and firmware?)
The tractor is a 2 hr drive away, and I'd like to have answers in hand before making the drive and making an offer on the tractor.
Thanks for any assistance.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #19
Like many newer tractors the valve is connected to the joystick via 2 push-pull cables. Allows the joystick to mounted on the fender in a very comfortable positions in my opinion. This pretty standard on many many cuts from most OEMs
Not sure what version of the ECM and ODB is used in 2016 but your success with an generic code reader may be limited. Some have a standard 16 pin automotive connector others do not. There is an LS code reader on the online market but no idea how well it works. Mine does ok reading and resetting with a mid range tool I have for vehicles.
You can try the parked regen but if not a dealer computer may be needed. Deleting the EPA stuff depends. The are couple of outfits that will modify your ECM to bypass so you can remove, some folks have done hacks on older 3037, etc to work old school and ignore the warning the ECM wants to throw...
I like like my XG3135 a lot and have learned how it wants to treated to avoid problems, knock on wood.
   / Wiring diagrams for LS XG 3135H and others are in this thread. #20
Great info; thanks! (Can you tell I've only been around tractors that are almost my age?)
Sounds like the cable will be an easy fix, and the regen is...only money. I'll see what the seller will do.
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
KBH 25T Tender (A56438)
KBH 25T Tender...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A56438)
2010 Doyle 32ft...
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56438)
2015 Bobcat S650...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2024 CATERPILLAR 305 CR EXCAVATOR (A60429)
2024 CATERPILLAR...
