   / Your last generator Maintenance Run
I'm getting tired of having to hook up my PTO generator every time we have an outage. I heat with fuel oil, so I'm thinking of getting a diesel 10 - 12KW model. Instead of an outside enclosure, I want to locate it in the back of the barn with a thru wall exhaust.
Any suggestions?
Somebody on here (my lousy memory again), in your NE (Maine?), did a really nice build of a post-card worthy gen "shed" (excellent Winter shot posted, once done). I did hear "in-barn", but mentioning that ^, for the clean thru-wall installation (IIRC) - might be worth finding out exactly what was used on that one.....
I've never dealt with these folks, but they have been around for a while..... in that size of dzl, they run Perkins and Yanmar - should be solid units I'd suspect.
https://www.auroragenerators.com/home-generators
Rgds, D.
   / Your last generator Maintenance Run #7,042
Any suggestions?
I'd be mildly concerned about exhaust leaks & an increased chance of fire. Definitely doable safely, but you just have to pay a bit more attention to proper ventilation for fumes & heat. Personally I'd stick it under a lean to or something rather than in my barn.
   / Your last generator Maintenance Run #7,043
Rgds, D.
90cummins perhaps?
   / Your last generator Maintenance Run #7,044
Any suggestions?
Kubota makes a nice 12kw diesel unit, not cheap around $11k
   / Your last generator Maintenance Run #7,046
   / Your last generator Maintenance Run #7,048
take a look here lots of models.
Thanks for the link. Best price so far on the Kubota.
I like the GL1100 Lowboy due to it's 27" height. I want to put it on the back wall of the barn under a window, using a thru wall exhaust. It also has a remote start kit, which I can place in the house.
***Update***
Absolute Generators in Iowa beat the Central Maine Diesel price on units I'm looking at by over $1K.
   / Your last generator Maintenance Run #7,049
No good place to mount it outside. The barn is well ventilated and not usually inhabited. I'll put a CO detector nearby anyway. The 1" exhaust pipe on the Kubota need only be extended 12" to go thru the wall.
I wouldn't consider doing this with a gas powered unit due to possible fume buildup. Especially true with spillage during refueling and storing gas nearby.
   / Your last generator Maintenance Run #7,050
Simply routing exhaust outside does not make for a safe install. To meet code on internal installs, there is also a need to bring in outside combustion air to the unit. There are also special firewall issues and fire safety devices necessary.
Some engines can be harmed by simply extending exhaust as it changes the pressures within the engine. The engine is designed for a certain exhaust system dynamics.
2025 AGT MX15RX Mini-Excavator with Dozer Blade (New/Unused) (A59225)
2025 AGT MX15RX...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
296385 (A57192)
296385 (A57192)
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
Club Car Carryall Electric Utility Cart (A55853)
Club Car Carryall...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
