PDF of MF2326 MMM operators manual posted
   / PDF of MF2326 MMM operators manual posted #1
Dmacleo
Etna, Maine
2010 MF GC2400 Owner, 2012 MF1532 User
trying to get one for neighbor, I can scan mine in make a pdf but...if some one already did no sense reinventing the wheel.
edit: title changed after I uploaded file
got a manual for 2326 had to trick system to allow upload.
reame to .7z for file extension and extract with 7zip program.
  • MF2326 Operators Manual.zip
   / PDF of MF2326 MMM operators manual posted #3
Thanks Dave. For anyone wondering, this is the 4283560M1 version of the manual dated 5/2014. There is a newer version of the manual, 4283560M2 (date unknown), available from AGCO pubs. I'm guessing that the newer version addresses some of the inconsistencies that exist for the GC1723/1725 series. I just got the deck, but one example of the differences is the height adjustment knob settings which are different than what is stated in the manual. I might download the M2 just to see, but it's $25 so you know, not really sure it's worth it. Also, the file posted is just a scan. You will need to run OCR text recognition on it if you want to go word searches.
****UPDATE**** I purchased the M2 version of the manual, and the differences are mostly in the safety section and some inconsequential wording differences here and there. The M2 manual, dated 2022, still shows the infinite adjustment on the GC in section 3 even though the new GC1723/25 series doesn't have that. AGCO kind of disappoints on these manuals, especially considering that you must pay for them.
yeah it is M1 version which is correct for my tractor.
GC2400 has infinite adjust not the 5 (iirc is 5) click positions your tractor has.
   / PDF of MF2326 MMM operators manual posted #5
Great. Thank you for the manual. I believe that the PDF format is very convenient to use, which is why I often use it exclusively. By the way, I recently found an online editor PDF Guru https://pdfguru.com/ which allows you not only to edit, but also to make notes and annotations to the file. In my opinion, this is a great feature that helps better structure the information within the file.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
PENDING SELLER CONFIRMATIONS (A51222)
PENDING SELLER...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
