Which fitting should I dislodge first? (Dirty Hands WS)
/ Which fitting should I dislodge first? (Dirty Hands WS) #1
charlessenf
Gold Member
York County, SC
Kubota B7800
OK, the reason Dirty Hands Brand is no longer literally 'popped up' this morning when the entire weld (24 =/- inches) let go all at once. Based upon the condition of the parts the weld was never done properly and there was no evidence of PENETRATION along the length of the break!
So, I have to dismantle this thing to convey the six-foot beam part to the welding shop and I can't begin to lift the cylinder much less the beam. I have no winch, chain hoist, etc. just my B7800 Kubota with a BOOM (let's hope not) POLE and FEL.
However that's not what I need to know. I may have no choice but to disconnect the cylinder from the two hydraulic hoses attached to the Control Valve body. See pictures. Which part do I try to UNSCREW (for lack of a better term)? A or B
Then, what to expect in terms of fluid discharge? Torrent, flood, a little, a pint?
Then, what to do with the loose open ended hoses? (to keep from contaminating the rest of teh system, etc.
Thanks
/ Which fitting should I dislodge first? (Dirty Hands WS) #2
B is a swivel fitting, so you hold A with a wrench and spin B with the other wrench.
It will leak a little bit of fluid out. Not an huge amount but it's oil, it doesn't take much to make a mess.
I managed to dismantle the thing wo needing to disconnect the hydraulic hoses. Putting it back after the welding is done - well, knowing which fitting to turn on may prove essential! Thanks for the succinct feedback. Much appreciated. I'll try not to make a mess :)
/ Which fitting should I dislodge first? (Dirty Hands WS) #4
A trick: put a shop vac in the hydraulic fill hole (not deep enough to touch the fluid 😀 ), and turn it on. When you open a line, it will suck air through and keep the fluid from dripping everywhere.
Right Arm! Great tip! I heard something like that was a thing to help changing the hydraulic fluid in my B7800 tractor. Bought the fluid years ago - still waiting to get a Round Tuit - hate to rush into these things!
Also looking for a great HOW TO CHANGE HYDRAULIC FLUID IN A B7800 video!
This time, I managed to remove that massive cylinder off the beam and onto a support wagon without disturbing the hydraulic hoses or their connections. :)
I wish I could sue LOWES for the cost of repairing the damned thing. After all it was the 'perfect' manufacturing defect in that the nearly thirty inches of weld never penetrated anywhere along the first two feet or so and the surfaces were smooth, flat and, but for the rust, clean as a whistle!
It is one of the situations where the limitations of warranty expiring do not apply since the defect was built into the product in such a way that only a catastrophic failure would disclose it. That is there was no way the customer could tell the weld was superficial without putting the part under stress sufficient to pop the parts apart!
Under the Law, every product comes with an IMPLIED WARRANTY OF SUITABILITY FOR INTENDED USE. In this case applying 12,000# of pressure to dislodge the anvil from the log by pressing the log against the part of the frame that came apart. TEXTBOOK "factory Defect."
OK, I got the thing back together and split a large log into little pieces and, then checked the leaking fitting - it was leaking, of course.
I got a wrench and prepared to apply all my aging muscle to torque that fitting tight.
When I applied pressure to fitting C, it was loose and I started tightening up. One turn round, two turns round, then three an four before my wife shouted "hey the hose is kinking" - and she was right.
Apparently, the 'swivel fitting' wasn't swiveling like my sister Kate. Rather it wasn't budging at all. So, Do I apply a wrench to B turning it as I tighten the fitting on the pump body C ? https://www.tractorbynet.com/forums/attachments/241007-splitter-split-3-jpg.1471292/
Turning A & B in unison (and direction) with the turns necessary to tighten C.
That worked! Putting a wrench to the 'swivel fitting' A and not the hose fitting B did not work - it loosened the connection between A & B!
Regardless, all is tight now and the leak appears to have been corrected.
Now to address the Hydraulic Fluid Tank's Dip Stick issue! The steel is so clean and smooth and the fluid so clean and clear that it is difficult to 'get a reading' at first glance!
/ Which fitting should I dislodge first? (Dirty Hands WS) #7
Why would I want to suck crud out of an external line on an implement into my tractor reservoir?
Kinda like saying close your mouth when barfing so it ends up going through your nose instead.
I let it drain out and use gravity as my friend to stop it from emptying out if required
I suspect the vacuum doesn't 'suck crud.' Rather it provides just enough vacuum to counter any potential outflow from the hose or fitting one is separating.
Having defended the idea, I must admit never having tried it.
/ Which fitting should I dislodge first? (Dirty Hands WS) #9
It works. Have used that method to prevent fluid lose while changing the hydraulic filter on a skid steer. Also have used it when I discovered that the aluminum sealing washer had come off of the drain plug on an ATV. Applied suction to the dipstick tube hole when the drain plug was removed and installed the washer and put the plug back in and didn't loose a drop of new oil.
/ Which fitting should I dislodge first? (Dirty Hands WS) #10
View attachment 1472901View attachment 1472902View attachment 1472903
Why didn't you just hook up to the splitter and move the whole unit to the weld shop? Me thinks that would've been easier & lots faster? No matter now since you've gotten it fixed, just curious.
Why didn't you just move the whole unit to the weld shop?
1. I could do it. (disassemble and reassemble as needed).
2(a). They would have had to do that work in order to straighten the bent rail*, reposition and weld it (3/8" Steel).
2(b)(i). I would have had to pay Shop Rates for their labor.
2(b)(ii). I work much, much, cheaper.
3. Would you believe it cost me $75 to have them remove the bent rail; straighten the rail, weld the rail back in place and paint it to match the other side?
Seriously, judging from the prices I see bandied about here I got the work done for less than a third the going price.
But, don't correct me if I'm wrong on this 'cause I'm so happy with the price I paid.:D
* Did you see the pics of the damage before?
/ Which fitting should I dislodge first? (Dirty Hands WS) #12
It's just a home owner grade log splitter. Granted it shouldnt fail that easy but not a big enough deal to get a lawyer.
Well, actually, one does not need a lawyer in Small Claims Court.
I once sued General Motors and A Chevy Dealer in Palm Beach County, FL appearing pro se and won. I did pay for a court reporter to get the attention of the judge.
In this case, I don't know where the documents (receipt, etc) might be and I'd likely have to delay the repairs to give Lowes an opportunity to repair it on their dime. Considering what I paid to repair it, suing was not worth the effort.
But, don't knock it, it works. I recommend everyone take a couple of courses in basic business law. I filed my own divorce papers - total cost was something like $33 and it worked just was well as a Lawyer-assisted divorce (so far, she's not come back!).
Don't agree with that logic. A 'homeowner' log splitter should be held to as high a standard as one designed for professionals. Tons of force are applied, that thing (20# Anvil) could have struck my wife in the face, crushed her arm or hand.
It is difficult to tell how much PENETRATION the welder is achieving after the product is welded, painted pretty colors and sold to the 'homeowner' - but the welders know that pretty don't equate to penetration and Dirty Hands should have done quality checks enough to know that their boy didn't know how to weld properly.
At law, one has the right to expect a product is in all ways, suitable for intended use. If the defect is hidden, as in this case, the warranty extends to the date of the discovery of the defect.
Hopefully, the 'homeowner' will survive such discovery.
/ Which fitting should I dislodge first? (Dirty Hands WS) #15
Personally I think it has serious design flaws so it can be made on the cheap..... Get it operational and sell it off and real quality made one....
