How to make Railroad ties last longer?
   / How to make Railroad ties last longer?
I think I am going to bite the bullet and get a scoop of gravel to put against the ties. I have a material yard right next door to my property that lets me come in and grab a scoop at a time. (I know, what was I complaining about right?). I did a quick calc and it is about 20 cuft. Which is about 1 bucket full on my machine. I also have some left over road fabric that I can use to hold it up against the ties while I spread the dirt up against them. Kind of a no brainer, just an extra step I didn't want to do. But it is best if I do I reckon!
Well, its done!! It was not easy to hold 57 rock against the ties before I backfilled. Used geotex fabric stapled to the bottom then filled it and then pulled it to the top. Worked ok, and I ran out of stone. But whatever, its done!! I backfilled it with some nice dirt I got for free from a project down the road. It was LITERALLY the perfect amount. No pics because it was dark by the time I finished. I will snap one tomorrow. I have some questions about super dry fill, and rain and extra compaction but I think I am going to start another thread. Stay tuned for pics. Only afters because I am the worst at taking befores.🤦‍♂️
   / How to make Railroad ties last longer? #26
To make railroad ties last longer, consider applying a few effective strategies. First, placing a plastic barrier between the ties and the soil is a great idea; this helps prevent moisture from seeping into the wood, which can lead to rot. Additionally, applying a used oil treatment can provide some level of protection against moisture and pests, but be cautious as it may not be environmentally friendly.
Instead, consider using a wood preservative designed for outdoor use, which can enhance longevity without harmful effects. Lastly, ensure good drainage around the ties to minimize water accumulation, as excess moisture is a primary cause of decay. With these steps, you can help your railroad ties withstand the elements and last longer in your mom's backyard shed project.
Are you a real human?
I was wondering the same thing. Sound very AI generated huh? Their other post sounds the same. Very interesting if AI is going to start jumping into the mix.
   / How to make Railroad ties last longer? #28
If you are talking "real" RR ties - they should last forever with no added help. I have four - serving to hold up two gates. Installed in 1982 and still solid as a rock.
If you are talking about the crap sold at you local hardware store. Well - you are going to get exactly what you pay for.
   / How to make Railroad ties last longer? #29
Built a small porch with real creosote oozing 4 railroad tie posts.
For 30 years they looked fine and then moving a refrigerator the fount that termites had completely hollowed out the ties from the inside.
The outside 3/4 to 1.5” perfect but nothing inside except very upset termites…
   / How to make Railroad ties last longer? #30
In the heat of the summer - you can smell my RR ties from twenty feet away. Lucky - around these parts, no termites. We do have the occasional wood boring bee. Don't seem to like my cedar home or those "juicy" RR ties.
However - there must be a valid reason that prestressed concrete ties are now being used.
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
