What do you call these bolts/pins/fasteners with a hole in them?
   / What do you call these bolts/pins/fasteners with a hole in them? #1
CobyRupert
Super Member
Washington County, NY
JD 5075E
A hardware question: What do you call these (silver in picture) pins/ bolts/ fasteners that are like a bolt (have a thread and nut or bolt at one end); but the opposite clamping end has a perpendicular hole drilled through it to insert and hold some other rod?
And where can I get some?
I realize I’m going to need a length, diameter, and “hole diameter” measurement, but someone must sell them?
   / What do you call these bolts/pins/fasteners with a hole in them? #2
I think they are called adjusting clamp bolts. Dont know where to source.
   / What do you call these bolts/pins/fasteners with a hole in them? #3
A search for rod clamps turns up lots of variations.
I haven’t found anything that looks close. The rods being clamped are 5/16” o.d.
The fastener is mounted through a 1/4” hole in the (black plastic, “hollow”) mount where a nut is applied to fasten it to the mount.
I noticed my top picture looks like the fastener uses a nut on one end, whereas the bottom picture seems to use a bolt that goes through the mount into the clamp.
Seems like there’s various styles. I’m just trying to find one.
   / What do you call these bolts/pins/fasteners with a hole in them? #5
Not much help, but maybe the picture is useful.
Bruce
   / What do you call these bolts/pins/fasteners with a hole in them? #6
Would something like this work for you?
They are not cheap, but then I'm not sure what your application is:
Are you trying to duplicate exactly what you have shown in your picture?
   / What do you call these bolts/pins/fasteners with a hole in them? #7
No, I was just looking for a “bolt” with a hole through it (eye-bolts) . Seems like it should be easy, right? Oh no, not for me! Lol
I have rods and mounts like in the original pictures, I’m just missing the “eye-bolts” thanks to the washboard dirt roads in the hills of Benson Vt.
The two bolts circled in picture below are exactly what I need. I finally found the whole kit by searching: 8mm eyebolts bike rack…which, believe it or not, was an very long evolution of Lou’s pipe clamp suggestion. Lol.
2006 FORD F-750 WATER TRUCK (A50854)
2006 FORD F-750...
2015 Volkswagen Jetta TDI Sedan (A50324)
2015 Volkswagen...
71057 (A49346)
71057 (A49346)
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
