branson 2910 hydraulic line
/ branson 2910 hydraulic line #1
redtractor2910
branson 2910
hello. newbie here. I have a Branson 2910 tractor with a hydraulic problem. where the main metal hydraulic line coming from the pump goes along the left side and ends just in front of the back left tire, I cannot find anything that will connect a new hose to that threaded end. It looks like it’s a 1/2 diameter size, and I’ve used some swivel connectors to connect it to a hose but I guess the swivel wasn’t strong enough to hold the pressure. The previous hose had a leak, so I am trying to repair it. It had a British connector on it and when I got the new hose the new connector doesn’t fit right. i’ve tried every connector. I can find to connect it to a 3/8 inch hose, but now I have run out of options. Any ideas? Thank you in advance.
/ branson 2910 hydraulic line #2
I suggest you take the original hose to a local hydraulic shop and have them make you a new one. They can size and get the proper fitting for you.
I was confused in the swivel fitting you tried. Did it fit correctly but failed in the swivel part? Was it a plumbing fitting instead of a hydraulic rated fitting?
Pictures of the fitting end may help us help you as well.
  • Good Post
Reactions: 1hp
/ branson 2910 hydraulic line #3
I find that with a steel line with a style of fitting I can't (or choose not to) match, I can cut the line, make a fitting that's easy to work with and braze it onto the line. From that point on standard, easy to find fittings and/or hose ends can be used.
Pictures of the fitting end may help us help you as well.l
thanks! i found a mobile hose repair company and they hooked me up. the swivel coupling wasn’t graded for the pressure from the pump.
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A61569)
2014 Glasstream...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2015 New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
2015 New Holland...
International Engine (A61568)
International...
UNUSED ATS ACE80-80 GALLON ELEC. AIR COMPRESSOR (A62131)
UNUSED ATS...
