The Life of a Custom Mowing contractor
   / The Life of a Custom Mowing contractor #1,021
Moldy hay kills horses, of course farmers know this but... bottom small bails in a stack mold sometimes and backyard horse people don't know enough to recognise the problem.
   / The Life of a Custom Mowing contractor #1,022
Yes, wish I had started earlier, but I would have done it a little differently. Probably would have gone bigger sooner rather than incrementally small growth, but didn’t want to get in over my head.
So what’s wrong with the guys that cut your land? How do you know they don’t want to?
Also, “cut” hay is just the beginning. I like to think of it as “bale” hay. That’s the finished product before its’ sold. ;)
There is nothing wrong with the the guys that cut the hay. They are good people that try their best to create a good product in the face of weather and breakdowns. From a person that is just a casual observer, it doesn't look like they ever have any fun doing it though. You are the only person I've interacted with that truly enjoys the work.
From my analytical mind, it seems there is a huge trade off in that business. You either use budget friendly equipment that is always in need of work, or you use new equipment that is always in need of a payment. There is no sweet spot in the business where you can leverage your equipment expense to maximize output at a minimum input. In other words, there is no cheap margin to obtain.
It's a tough business and I commend people that do it. It's one of those things that needs to be done, and I don't know what would happen if there weren't people out there willing do it at the huge expense it requires. One thing that is good, the margins are not enough to allure big ag into it, so the local farmer should be pretty well employed in the business for awhile.
For me...I just want my meadows cut...What happens after the cutting is up to the neighbor. He has left cut hay to be dragged the following spring to act as a nitrogen to cut back on his costs if hay is plentiful that year.
   / The Life of a Custom Mowing contractor #1,023
In my area I don’t think there are a lot of people that make hay strictly for sale. Most are making it for their own cattle.
   / The Life of a Custom Mowing contractor #1,024
Boy isn't that the truth HD . . . fortunately I turned over that to my son HD. (y)
   / The Life of a Custom Mowing contractor #1,025
Happens once in a while. I believed last Saturday’s forecast that the weather would hold through Tuesday/Wednesday.
Then a Hurricane changed my plan of action for me.
60 acres of hay on the ground, soaked to the core.
This is why having the option to sell as mushroom hay is such a great thing.
HD, thank you for cluing me in on mushroom hay. ;)
It actually keeps many of the big bale hay farmers around here honest. No need to sell low grade hay to people when you can sell it to the mushroom companies. Anything that isn’t clean and dry goes to mushroom.
Many problems can arise in hay. A horse around here died because the bale it was eating from had a dead animal deep inside the bale that got baled up, unknowingly and caused botulism.
I’m surprised that doesn’t happen more often. Small bales are safer to feed because they are handled with human hands before being fed.
I love the challenge. It inspires me to rise up to it and defeat it. If you knew me personally and saw me, you’d understand.
In some cases you are right, but many of have found the sweet spot. There’s a lot of gross income, but the expenses can be quite high. Depends on your repairs/parts invoices for the year. Sometimes you get the bear, sometimes the bear gets you. It IS an equipment-oriented business. The key for me is to have off-farm work that supplements my income. I consider my business as a “large property management” business. We take on anything from farming, to tree work, to brush clearing, large area mowing, etc.
Any kind of farming or bull-work and we have you covered. If all I did was farming, I would acquire more land and make more gross income from hay sales. We could never have enough mushroom hay to sell. Its a unique area with a unique demand. We have hay trucks pouring into my area 6 days a week loaded with hay.
Partially correct. The expenses are great if you must have newer equipment. I run mostly ~10 year old equipment. It’s fine and doesn’t really give me too much unexpected trouble.
However, in MY area, bigger farming businesses are more than happy to gobble-up smaller ones. This just happened in my area. A medium sized hay farmer went under. I was given about 150 acres and another much larger farmer got 500+ acres.
In MY area, the small guys are dropping like flys.
That happens here occasionally. 2nd or 3rd cutting can be thin enough to be left as fertilizer and the existing grass stand will grow through it.
   / The Life of a Custom Mowing contractor #1,029
I keep expecting to find a dead animal in my round bales. Snakes seem like the most likely animal to get baled, but so far, in ten years of buying round bales, the only thing I've found in a bale is a softball.
   / The Life of a Custom Mowing contractor #1,030
I've seen several snakes in small square bales, a few in rounds as we feed them out. Have found a few wood chuck carcasses in the rounds. Usually find the "interesting" pieces while cleaning out feed bunks.
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
NEW HOLLAND HAY CUTTER (A58216)
NEW HOLLAND HAY...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
CATERPILLAR 80" QUICK ATTACH BUCKET (A51406)
CATERPILLAR 80"...
2018 HINO 338 26FT CDL REQUIRED BOX TRUCK (A59575)
2018 HINO 338 26FT...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
