What to fill this in with?
   / What to fill this in with? #1
Shenandoah MF1760
Gold Member
Livingston, East Texas Piney Woods
Massey Ferguson 2020 MF1760M
I have this set of concrete strips that used to support a doublewide.
I've considered having cement poured between the strips, but that seems like it would cost too much and be too much work for what I'd gain.
I intend to put my 5th-wheel RV trailer on the left two strips where the septic inlet is, and my shipping container on the right two strips. I could possibly get away without filling anything in if I had the ability and willingness to attempt backing the RV in, but I'm unwilling to take the chance and have to listen to the wife for the next few years if I messed up.
I'm considering having a dump truck full of something brought in, but I'm unsure of what would be best; gravel, fill dirt? I'd want something that could be driven over should the RV run off the strip when back in.
This is East Texas and the ground is sandy loam and red dirt. Everything is stable, those stips were put in in '98 and are still level. The strips start out at ground level at the bottom of the picture and rise to about a foot high at the end over by the truck 68 feet later.
Red dirt when dry is as hard as the iron oxide that gives it its color, when wet it's as slick as an ice skating rink and is muddy and loose.
So, what does the hive mind think would be the best solution? I appreciate any an all comments - educational and entertaining!
   / What to fill this in with? #3
If you don't want to pour concrete that would be perfect application for what we call "crush and run" Around here it is crushed limestone 1" and smaller along with a good portion of dust. When it gets wet and then dries its very hard.
   / What to fill this in with? #5
Crushed Concrete might be a cost effective solution.
   / What to fill this in with? #6
Do not use "gravel" - that would be like putting marbles in there
   / What to fill this in with? #7
I would put 3/4 inch minus gravel, or what they call crusher reject... I would be against pure stone or wash stone as it doesn't compact, sand is dirty and gets in everywhere so yes 3/4 minus gravel.
   / What to fill this in with? #8
I would dig it out, add a bit of road-base gravel, and then lay in cmu, with the cells vertical, add soil to the cells, and seed it with grass. Quick easy solution permeable, green like the surrounding turf, and able to support loads.
If you go with gravel, a 3-inch layer of 1/4 or 3/8-inch pea gravel, (98% 3/8 minus, 95% 1/4 plus) treated with a pre-emergent herbicide, deters mice, and most snakes. They don’t like walking on it, and can't burrow through it.
I've read that Roman roads used limestone as part of the composition which is why they've lasted so long.
They call it "crusher run" here and it's not readily available although 1" crushed limestone is.
I'll have to see what a truck load would cost.
Digging it out would be a lot of work. This was the level foundation for the double-wide which they then raised and supported with blocks and skirted. Meaning that since no one would see it after installation, it was a good place to put excess concrete and hide anything else they weren't taking with them.
Also, it sometimes rains to excess. I got almost 30" in one month this year.
2018 Ford F-550 Altec AT48S 47ft Bucket Truck (A55973)
2018 Ford F-550...
2000 Cummins DGDB 100kW Standby Diesel Generator (A56857)
2000 Cummins DGDB...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
MASSEY FERGUSON 275 TRACTOR (A58375)
MASSEY FERGUSON...
(INOP) CATERPILLAR 914G WHEEL LOADER (A52705)
(INOP) CATERPILLAR...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A58017)
2020 INTERNATIONAL...
