Good morning!!!!
   / Good morning!!!! #196,812
Buppies, I've looked at their site but have used tirerack for a long time.
Have bought a lot of tires from them, including six for this motorhome that I went to the DE warehouse and picked up to save six percent tax.
But if there is a good local Michelin/Goodyear/Pirelli/Cooper dealer nearby, the trick is to print out the page from tirerack showing you did your homework and this is the tire you want. They can see the price just fine, and I've found I just wait for the return estimate and it's always close to tirerack.
so I educate myself on tire rack first and then try to do business locally.
someone has to install them and balance them and having a good tire shop
is valuable. I figure 15-20 bucks a tire to install and balance but I may be behind the times.
   / Good morning!!!! #196,815
I get my tires for the Dodge locally, the garage deals with discount tire. I know I pay list price + mount and balance + 13% tax, but I don't care. That garage takes good care of me.
Anti-freeze done in the Kioti. I thought I had concentrate, I didn't, it was pre-mix and I diluted it another 1/2 a gallon. So now it is only good for -20°F. I am ordering concentrate and will drain the overflow tank and add the concentrate to that. I kept the ball valve to the heater shut off, so there is also -60F in that. When ever I need to add some more I will add the concentrate. Someone put pre-mix in a concentrate bottle. Oh well, stuff happens.
   / Good morning!!!! #196,817
work, and a pain in the butt when the driveway isn't froze.
I turn my back blade around backwards like this )>
> = direction of travel. That forces the snow into the gravel and creates a smooth surface for when the serious plowing gets here.
   / Good morning!!!! #196,818
69°F and .24inches rain.
Dr happy with pressure in Sophie’s eye, healing well. No prescription changes. Vision improved to 20/80.
Hopefully dry enough to resume mowing, but will definitely have to raise the deck.
Taking Sophie to Lobster dinner tonight. No particular reason other than restaurant finally having what they call Angry Lobster night, 1st time in a couple years, so just a special treat for my special lady.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #196,819
As do I it acts like a giant squeegee but it's still a pain in the butt, and then on my driveway you have to go over it repeatedly because even the 1300 pound back blade doesn't get it real clean when we get several inches of wet slop. A 14-16 degree slope (23-25%) is not a good location to get iced up.
   / Good morning!!!! #196,820
With rain, I started a camp fire.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2012 Kenworth T800 T/A Day Cab Truck Tractor (A55973)
2012 Kenworth T800...
