   / Your last generator Maintenance Run #6,972
The problem with a PTO generator on wheels is, you have to hook it up to the 3pt, or risk it flipping under a sudden heavy load.
I mount mine on a trailer with a wider stance. That way, all you need to hook up is the PTO.
With a caster wheel on the tongue, it rolls around the shop floor like a dolly. It's also convenient to haul around the property with the tractor.
   / Your last generator Maintenance Run #6,973
I went with a wide trailer also, but I do connect the tongue to the tractor. Some do, some don't.
I store the generator in a shed that the tractor doesn't fit into, so the trailer allows me to wheel it out when I need it.
   / Your last generator Maintenance Run #6,974
Can't imagine the damage a PTO half shaft could do, whipping around in the air, should the tractor and trailer ever manage to somehow drift apart. :D Best case scenario, they only wreck the PTO shaft, but they're still without power until repaired.
   / Your last generator Maintenance Run #6,975
3pt pto generator couldn’t be easier to connect and store. I agree pto generators need secured and driveline straight. Bought mine used and did change the platform as some are better than others. Spends considerable more time stored than use. Needs to be easy to deploy in all weathers.
Do use corrosion-X spray on pto splines, shafts and couplers on all equipment helps make easy, clean connections versus grease. Have noted no wear even with heavy cutters.
   / Your last generator Maintenance Run #6,976
I put a pto shaft on mine that has a shear pin in it, if it ever gets jammed up that way, the pin will shear and prevent damage.
SR
Some v. good looking gens and tractors on here lately ! :cool:
Liking the BigFoot mods on the gens...... need some off-roading videos of these too !
Rgds, D.
   / Your last generator Maintenance Run #6,978
Went up to my mom’s house today and got the 2 generators out of the garage for her. Brought them down to my garage to clean them up, service, and sell them. One is an old McCulloch 3300 watt job, with a flat head Briggs on it. Vintage 70’s.
The other is a Troy Bilt 13kw with an electric start Briggs OHV. Last time they were serviced was 2017. Probably haven’t been run much since. I need to drain whatever gas is left out and put some fresh in to test them. Luckily both have fuel shutoffs and were run until the carb was empty.
Picked up an oil filter and plug for the Troy Bilt from ACE hardware.
   / Your last generator Maintenance Run #6,979
that's a very cool McCulloch
a name from the past
   / Your last generator Maintenance Run #6,980
I remember as a kid, going with my dad to Sugarman’s in Eynon, PA to buy it. Was sort of a Montgomery Ward type store. They had a little of everything there. Actually there was a MW store down the road from S-man’s. Remember going there too.
We used that generator to run sump pumps, fridge and deep freezer, along with a few lights when the power went out.
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56435)
2020 Westfield MKX...
2018 Dorsey Dominator 55-Ton Low Boy Trailer, VIN: 5JYLB5537JPD06956, Honda Gas Engine, Electric (A59076)
2018 Dorsey...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Crane Truck (A55973)
2015 Kenworth T880...
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
1999 Volvo WG T/A Dump Truck (A55973)
1999 Volvo WG T/A...
