dodge man
Super Star Member
Most of my stuff is Stihl also. For me to say they are the best isn’t true because other companies make good stuff too.
String trimmers are made for a wide variety of materials, from thin grass to thick weeds. Those that will take thick weeds can usually handle a "brush" cutter type blade.What great input. I am attempting to compare/narrow down the trimmers by weight(would like around 10 lbs) and cc(may stay around 25). And, to keep it simple, will not be looking at any trimmers that accept attachments, that will just complicate comparisons. Probably will not go battery option as I did get a battery powered chainsaw and dislike it intensely, mainly for the lack of power.
Saw comments, on a lawn care site, that the Stihl FS94 can be persnickety in starting. Especially when warm outside. Have you found that so?
So you want to get her something that: does long grass/thick grass, no brush that requires a blade, goes for two hours, starts easy, handles 0.95 string., < 10lbs.The gal who does the weedeating on my property( I do all the mowing, w/tractor and finishing mower and Ferris zeroturn), when she weedeats, usually goes two hours at a time, sometimes more. I do not envy her, especially now in yellowjacket season. It is at times trimming around the house but mostly out and about in long grass/thick grass, along fencelines, hillsides/along the long drive I cannot get with the mowers, along a stream. She has no interest in using a blade(one older Shindaiwa is set up with a blade and she does not use it). She does not like a weedeater that needs to be pulled more than twice to start. I do use 100% gas and mix it with Stihl oil. The string we use is .095
Maruyama here. On my 2nd one now for 8 years, the first one lasted 19 years. 23cc - NEVER a starting issue on either one. I use it HOURS at a time, .095 Oregon square string on speed feed head(s) - I go thru heads every 2 or 3 years. Light weight (10 lb) and less vibration than Husq and others I've tried.
