You Have a Cab?
/ You Have a Cab? #1
rockinbbar
Gold Member
South Texas
New Holland Powerstar 120, Powerstar 75, New Holland c245
Everything I have has a cab.
This is just one of the many reasons.
Are you a cab, or open station type?
/ You Have a Cab? #5
So glad I got a cab. Helps a lot whether it's cold, warm, dusty, or raining.
Yet, I use the little tractor that only has a canopy a lot more often...when the weather permits.
/ You Have a Cab? #6
I upgraded to a cab for snow plowing, but it's definitely a plus in the summer months also!
We had a blizzard come through in 2016 that was miserable on an open station tractor for 24 hours of seat time. I had a cab that following April.
/ You Have a Cab? #9
I only ran this machine about two hours since I cleaned it. Not eating dust in the cab is nice.
/ You Have a Cab? #10
The only reason I have an open station is because a cab wouldn't fit in my garage.
/ You Have a Cab? #15
3 with cabs, little Kioti 2620, Branson 8050, and NH 8160, then the old IH 574 open station that primarily sits on the pto generator.
/ You Have a Cab? #16
Isn't a soft cab as miserable as a Jeep's soft top?
At least with the Jeep there's a glass windshield and wipers.
Granted there is no glass windshield and wipers, never had a need for them. Main use was to keep warm in the winter when moving snow. Snow just blew off but cab kept me out of the wind and snow and I was perfectly warm even on 0 deg days.
This the cab I have for my tractor:
/ You Have a Cab? #17
I've got the optional glass windshield for my Original Tractor Cab. I didn't get the wiper but I've never needed it. After 13 years, there are a few scratches on the side and rear plastic windows but not enough to affect visibility. No heater but it cuts the wind and cold enough that I'm comfortable in Carharts.
/ You Have a Cab? #19
My M6040 is open station with a canopy. I enjoy the fresh air and ability to hear whats going on when using implements.
I seldom use the tractor if the weather is bad. Being retired usually means most anything can wait.
An example - I use to get up very early to plow snow on my mile long driveway. Not any more.
/ You Have a Cab? #20
Also - I don't really mind the heat so much here. When it does get hot - the humidity is always below 15%.
If for some REALLY important reason I might have to go out in the cold and snow. My Eddie Bauer down jacket, pants and gloves are a whole lot less expensive than a cab.
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
213324 (A64279)
213324 (A64279)
2011 Ford Fusion Sedan (A61574)
2011 Ford Fusion...
2022 EZ-GO ELITE...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
John Deere 755 (A64119)
John Deere 755...
