   / Your last generator Maintenance Run #6,931
I wonder what other people do to get the noise level down. My gen is LOUD. Tried adding an automotive muffler, but that didn't really work. And tried running the exhaust under water. That also didn't work. Figured out if I set it up to reflect noise away from the house, it is much better. The noise is in the single piston engine design. Even outside on the ground, we can feel the vibrations inside, panting the windows.
Exhaust noise can be difficult to control with universal parts. Manufacturers spend a lot design of dollars getting this right (or wrong, remember every GM product in the early 90s). You do want to be careful adding restriction to the exhaust as this will drastically increase cylinder temperatures and can cause piston and ring damage.
You didn’t say what size generator you have but one very effective way to reduce noise is put your generator in a hole deep enough to block any line of sight to your house. Much of the primary sound travels mainly in a line of sight path until it bounces off something.
Make sure the hole is wide enough to allow full ventilation and access to the unit (don’t cover the hole). This doesn’t work everywhere, in particular you need to be sure you don’t flood your unit if it rains.
Without knowing the size of your generator it’s hard to know how much vibration it is creating, the obvious solution is to move it further away but depending on the soil type, digging a hole may also help if you get below the soft spongy soil onto rock or clay that is more solid. Other than that, experiment with soft or springy materials under the unit. On large units, spring isolators are used however they cost more than most small generators.
Sometimes the cheapest and simplest fix is the most effective.
Those hours are what most of off grid systems are getting with there honda and yamaha inverter generators. Its good to see it reported by others every now and then! Regular maintenence, oil change intervals and spark plugs.
Most off gridders use thier generators enough in the winter that they use the cheaper e-gas. Its hasn't been a problem with continous use.
2024.... we are now @ the point where leaving a quiet gen running in Eco Throttle mode leads to better outcomes than shutting it Off and storing it.......
Notable.... how many times in practice, Saving The Planet looks more surreal than Alice in Wonderland....
Rgds, D.
   / Your last generator Maintenance Run #6,934
   / Your last generator Maintenance Run #6,936
I enjoy the noise a generator makes. Its when they dont make any noise my phone rings………
I repair generators.
Reminds me of the "smells like money" phrase used by many guys in the septic system repair trade.
   / Your last generator Maintenance Run #6,937
Fired up my Reds for their half hour of exercise. I set the small heater to 750 watts (sometimes 1500 for a few minutes) for the eu2200 and I just purchased a used 4800 watt 240v heater which gives the em6500 a good workout. Can someone confirm if I’m balancing the load properly by running this heater at the 4 prong L14-30 plug ?
   / Your last generator Maintenance Run #6,939
Construction heaters make great loadbanks. Used to have a bunch of outlets on a board to connect 9 heaters up either single phase or 3 phase to test gensets on mountain tops. A bunch of heaters are a lot easier to load into a helicopter than one big loadbank.
Let me get this straight.....
You get paid to play with Big Generators AND Helicopters !
I sure did sign-up with the wrong recruiter, all those years ago ! :cool:
Rgds, D.
LOT OF SHOVELS (A52708)
LOT OF SHOVELS...
Auger Drill Bit (A56857)
Auger Drill Bit...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
JOHNSON OUTBOARD MOTOR (A58374)
JOHNSON OUTBOARD...
