Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors?
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
I seem to be adding attachments that are used only infrequently or seasonally.
Some are showing exposure. (rust and paint deterioration)
Would a spray of boiled (or even raw) linseed oil be as useful as something like " fluid film", or NH undercoating/
This would be an "OVER PAINT" application.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #2
I use WD-40 for rust prevention in these kind of situations.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #3
It will definitely be messy, but probably would help with surface protection. I would find another solution. Linseed oil has a habit of never fully solidifying. It’s good for wood because it soaks into the pores, but you’ll cuss it whenever you handle your implements. Why not use tarps until you come up with a better solution? I don’t worry about surface rust for ground engaging implements like plows and blades. After using them, the blade surfaces will be polished again.
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #4
Mix it 50-50 with paint thinner to make your own much stronger version of "Thompson's Water Seal".
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #5
And it’s good for wood, not so much for metal. It will remain oily for a long time on metal surfaces.
Bo
It will definitely be messy, but probably would help with surface protection. I would find another solution. Linseed oil has a habit of never fully solidifying. It’s good for wood because it soaks into the pores, but you’ll cuss it whenever you handle your implements. Why not use tarps until you come up with a better solution? I don’t worry about surface rust for ground engaging implied plows and blades. After using them, the blade surfaces will be polished again.
Boiled oil does dry eventually.
I've never really had to handle a snow blower or snow blade. Not the chipper shredder for that matter. But the latter tool would surely collect DUST in any un-solidified oil.
I've got a gallon of each, boiled and raw linseed oil. I use the raw oil very seldom as it never dries except in seldom used wood.
WD-40 washes off with a evening dew.
NOT an option for me, BTDT
Check the MSDS for WD-40
Stoddard solvent with a bit of varnish added to keep the squeaks from returning so quickly.
Yes, I spent this entire day working on the BACK side of the snow blade.
I figure the front side will polish clean if we get snow!
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #9
Penetrol by Flood:
   / Is boiled linseed oil a useful rust preventative for seasonal implements stored outdoors? #10
Boiled linseed oil preserves wood tool handles and trailer boards.
I don’t think use on metal will work.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 Hyundai Santa Fe SUV (A56859)
2020 Hyundai Santa...
New/Unused 12 Ton Hydraulic Jack (A57454)
New/Unused 12 Ton...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
