1754 AC
/ 1754 AC #1
lpakiz
Gold Member
Greenwood, WI
MF1754 HST, Cab, 6 foot Front Mount Snowblower
1754 owner here, bought new in 2016. When new, the AC was really cold but lately it seems it's not as cold as when new.
As a former truck mechanic, I recall that when drivers complained about their AC not being cold enough, one of the first places I checked was if the valve for the HEATER was in fact, completely closing. (If the valve didn't close off tight, the cold air got re-warmed before exiting the ducts on the dash.)
My question is, where is this valve located in my 1754? I suspect it is in the roof of the cab, but do I access it from on top, by removing the roof, or is it accessed from underneath, by removing the headliner?
/ 1754 AC #2
You're right, a suspect heater valve is indeed a well known culprit in certain A/C problems. It comes up more often than people would think.
It's your choice of course, you can go looking for it in the cab, (whatever that takes) or do what I do. Look for a spot on one of the hoses where it's easy to reach, cut the hose and install one of these. (or something similar) Leave it closed until winter.
/ 1754 AC
Thanks Harry, that was indeed my "Plan B". I do tend to try to make the original design work as it was intended but......
/ 1754 AC #4
Is larger line going to compressor cold?
/ 1754 AC #5
Again, it's your tractor, your money, your choice. If you wish to "keep it all factory' then by all means, go for it. Most in cab valves any more are all plastic and prone to failure sooner of later. If not the valve, the cables that operate them. I've installed dozens of this type valves on many different tractors over the years and have yet to get any complaints about the aesthetics. Most people are just happy to have the A/C working.
/ 1754 AC #6
I prefer the quarter turn ball valves for mine, numerous choices out there;
/ 1754 AC #7
The first thing I do on an AC cooling complaint is attach the gauges. Do you even know if the system has refrigerant?
/ 1754 AC
I really don't need a tutorial on diagnosing AC problems. I've done plenty of that. Please go back and read the original post.
I only asked if anyone knew how to access the water shut off valve by the heater box.
/ 1754 AC #9
I for one, am aware of your question in the first post. That said, I merely offered my suggestion to save you from taking half the cab apart to get to it. As for where is it? Chances are nobody out here knows for sure so you haven't gotten that answered yet. Maybe you will. The heater valve will be close to the heater core, which will be next to the A/C evaporator. Is up in the top part of the cab, or under the seat? I don't know.
If I were working on your tractor I would start by simply taking a pair of vise grips, two flat washers, and pinching one heater hose flat. The run the tractor with A/C working for 1/2 hour and see if that has any effect on the issue. What comes next would depend on the answer.
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
Buckhorn Poly Bulk Seed Box (A66408)
Buckhorn Poly Bulk...
John Deere Van Brunt 10' x 7' Grain Drill (A66285)
John Deere Van...
Tow arm attachment (A64194)
Tow arm attachment...
