Have you ever heard of a defective ROPS responsible for injury?
/ Have you ever heard of a defective ROPS responsible for injury? #41
The roll over protection really is not a bother, I do have some trees and low lying stuff and it helps remove some of it, you just have to watch out for what springs back, some branches do not break (do not ask me how I know).
Seatbelts on tractors, mowers, etc etc is overkill IMO, anyways mine do not have them and I do not want them. I resent having to put on a helmet on a bicycle as I grew up with more freedom, but on a bike yeah it is a good idea for many reasons, i.e stops sunburn too ! I also have an old truck that never had seatbelts, but they made me put in a lap one, almost useless, but in a car, yes I do not mind.
I see much of this stuff for the ppl who either do not think, or are very thick or have evil Knievel tendencies.
Don't mean to be a buzzkill, but the seat belt isn't overkill, it's a necessary component to the system. It sounds like you've had the fortunate of never experiencing a tractor roll over. No seatbelt means you will be tossed out of your seat, and the odds are, have the tractor roll over on top of you, or worse, have that very ROPS be the instrument that crushes you because you're not in your seat. But then I live in NH and have plenty of opportunity to hang from the seatbelt and look down the slope at where I'd land as the tractor goes rolling on over me.
/ Have you ever heard of a defective ROPS responsible for injury? #42
So at the beginning of this year I dove under a an overhang by accident with my 2yr old kioti dk45 still on the flatbed trailer (parked in reverse)
Forgot to fold the ROPS.
Very slow speed, creeping under the overhang. As soon as I head the crash, I stopped.
The overhang part I hit is made from tonge and grove pine boards, about 1/2 thick, 5 inch wide. One 5 inch board was crushed, the next one splintered a bit, mostly intact though.
2x3 framing. And aluminum flashing covering the face. So if you were to kick that, you'd probably bust through.
The impact bent and folded the ROPS forward about a FOOT like it was made of clay. The bend started all the way from where it's bolted into the transfer case, and then in the middle, halfway to top, it folded, bent like with a pipe bender.
The amount of damage to the ROPS, compared to the damage to the overhang, BLEW MY MIND.
I still can not believe how a couple of half inch pine boards could have caused so much damage to something that is meant to save your life by keeping a ton or 2 of weight away from crushing you to death if you flip over.
There is no way that they would do anything to prevent any sort of injury, if they fold like this from a simple push.
2yr old tractor, no modifications or holes or anything. All stock from factory.
Worst part was having to wait for 7 months for kioti to get me new ROPS. The 2 vertical bars cost $1500 up here in chinada
And then there's me who forgot that the ROPs was all the way up due to driving on county roads and drove into the pole barn at some speed, breaking one of the 2x10 headers in half and pulling the other one completely out while also doing a pretty gnarly wheelie... 🤦‍♂️
Tractor was fine outside a few scratches.
/ Have you ever heard of a defective ROPS responsible for injury? #43
When I was about 13 my brother took a safety course. Back then one of the most common tractors on farms was the Ford N series.
Anybody who has run one knows how high geared they are. He was told a lot of kids were injured or killed on them because they'd be horsing around, pop the clutch and put it over backwards.
/ Have you ever heard of a defective ROPS responsible for injury? #44
When I got my tractor (2018) I realized that I really didn't know anything about tractor safety. I also realized that if I desired to maintain my health and well-being, I ought to learn about it.
Turns out there are NO tractor safety courses offered within a thousand miles of here! Nearest ones are Michigan and Minnesota, mostly for young people who need to drive tractors on public roads, and they are mostly on-line pamphlets.
In the six or so years I've been on Tractor By Net, I've learned a HUGE amount about tractor safety (and operation and maintenance), much of that comes directly from the experiences of TBN contributors.
And I thank you. Will Rogers once said there's those who learn from the experiences of others and there's those who only learn when they p*ss on the electric fence themselves.
I really, really prefer the first option.
Best Regards,
Mike/Florida
A note:
I needed to clear the spot in front of the shop this morning. 'Helping the neighbor to replace a water pump on his wife's car (Anything for the gals!)
This meant moving the B2601 down to the lower level.
Thinking of this thread, and wanting to be "safe", I re-positioned the ROPS from the fully folded position to the 45 degree back, half folded position. Yes, there is a pin placement for that position ;-)
When I got the tractor under the entry and shut down, I happened to glance up at the cast concrete header over the passageway. The ROPS tucked under by less than two inches!
Whew!, That would have made enough racket to wake me right up!
/ Have you ever heard of a defective ROPS responsible for injury? #46
You’re not making sense. Seatbelts on tractors are extremely practical with a ROPs. The ROPs prevents the machine from rolling completely over, and the seatbelt keeps the operator from falling out of the seat and being crushed by the machine.
I watched a friend hit a pothole with the RF wheel, he went off the seat to exactly where the rear tire would crush him. Fortunately, it stalled and he survived.
Obviously the fault of a defective ROPS!
Was the fault that the operator DIDn't land at the crush point, because that point never happened?
or......?
Oh! This is all so confusing...
"In action, Watch the timing"
Twice I have slipped off the operators seat FORWARD, to a point of having no control of the tractor. Seat belts are important.
In the snow skiing industry, the Sno-Cats, i.e. grooming machines, have places up on the dash board to put your feet for the extreme down hills.
(there are no foot controls on a snow cat, it's all at the hands!)
/ Have you ever heard of a defective ROPS responsible for injury? #49
or......?
The point was he was too stoopid to be wearing his seat belt. If he had been, there would be no story.
/ Have you ever heard of a defective ROPS responsible for injury? #50
Lots of people want to control your life. How you react to that is your decision. :eek:
Very well stated. I'm the 'captain' of my own ship so I decide 100%. Been farming for over 20 years now and still have all my fingers and what is left of my hair so my decisions must be working, for me.
/ Have you ever heard of a defective ROPS responsible for injury? #51
Speaking of ROPS:
Too bad I can't post the video directly, instead of opening a new tab but it is what it is. It's a tractor roll over simulator for the skeptical ones on opening a Facebook video.
/ Have you ever heard of a defective ROPS responsible for injury? #52
Speaking of ROPS:
There are more videos down in the safety forums... Tractor Rollover Demo Pictures and Videos
Unfortunately you have to download to watch them.
/ Have you ever heard of a defective ROPS responsible for injury? #53
Mine wouldn't have because- drum roll please...
My seat safety switch is disabled!
/ Have you ever heard of a defective ROPS responsible for injury? #57
Lots of good info here and discussion. I'm a retired tractor engineer and used to regularly read accident reports. Two other scenarios come to mind that lead to tractor rollovers that operators should be aware of: trailer loading/unloading and downhill runaway/loss of control. These show up all too often. I know it is a pita but ROPS up w/ seatbelt to load/unload. Know it has a high accident rate.
Also, runaways lead to rollovers far too often. If one tire breaks traction, it can spin backward allowing the opposite side to roll forward with the tractor. You and the tractor are going for an uncontrolled ride! So before the decent, ROPS up, seatbelt on, and diff-lock engaged. Hope this helps!
/ Have you ever heard of a defective ROPS responsible for injury? #58
You’re not making sense. Seatbelts on tractors are extremely practical with a ROPs. The ROPs prevents the machine from rolling completely over, and the seatbelt keeps the operator from falling out of the seat and being crushed by the machine. Without a ROPs it’s better to not wear a seatbelt and being lucky enough to jump far enough away to avoid being crushed..
Well my tractor was made in the 60s, another the 80s, both have roll bars, neither has a seatbelt & I do not want one either.
With a seatbelt or without, your arms and legs could still be crushed, without a seatbelt you would have to jump in front of the bars downward path I imagine to get your body
/ Have you ever heard of a defective ROPS responsible for injury? #59
Yeah, I get what your saying if it is a violent rollover, I guess ppl down here do not drive around so fast, an accident is just that, but some people are either brain dead, careless, reckless or a combo of any or all 3.
I have been in car accidents with belts and without, at far higher speed than I ever drive my tractor, and perhaps I was lucky not being hurt in any including a roll over once, but frankly on a tractor, I would be more worried about it may be gonna run away on me & would like the option to get out quick or hold on and stay with it.
Just reminded me a family member rolled his not that long ago, it has no belts, he stayed within and did not get hurt, again, maybe luck, but I bet there are more machines without a belt than with, only newer ones down here will have a belt, and our govt is right into managing every aspect of your life, so if it was critical, they would force installation & yes, even on private property our gov can force you to do things.
/ Have you ever heard of a defective ROPS responsible for injury? #60
Additionally, driving in reverse - the highest amount of torque available in a motor vehicle - has the ability, even at low speed, to put an immense amount of pressure on something.
Not all, but by far, most pickup trucks and cars, have a reverse gear ratio, equal to the first gear, or with a even lower numerical ratio. ( less torque) than first gear forward.
My tractor reverse gear results in all gear position being numerically 1.05x of forward, so essentially the same.
Tire traction is worse in reverse.
I’m curious what makes you think you get more torque going backwards?
Engine (A59228)
Engine (A59228)
Unused SDJ-4000 9,000lb Two-Post Electric Auto Lift (A55851)
Unused SDJ-4000...
2018 Kia Soul SUV (A59231)
2018 Kia Soul SUV...
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2015 Ford F-550 Enclosed Service Truck w/ Liftgate (A59230)
2015 Ford F-550...
