Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,036
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
A bit of an update.
Yesterday, I cobbed the three gauges into a board with cutouts and got the third T mounted. Hooked gauges up and went out for a test.
First thing I noticed.... the right (recently rebuilt) motors gauge was boucing around like a kid in a bouncing house. The left (second motor on that same circuit) was very silent until it hit some tall grass then it bounced up.
I'm guessing this means the second gauge might have been too loose and fluid was getting by much easier than the first one. I dismounted and tightned it down 1/2 turn. Now, they both started to act .....how to word this.... "more calm". They still bounced but it wasn't one being schizophrenic while the other was dead.
Oh, side comment, I had put zip ties on the three 30' of hoses (each was 30' long) I didn't know how much I might need to allow for pulling when in a turn. I had wrapped it around the grab bars to climb into seat.... used zip ties to keep it together.
I did NOT however, account for the turns I was doing to loosen it up a bit.... just enough that one of the hoses got under the lip of the mower and hooked by the blade. Interestingly, the hose wasn't chopped up (it was destroyed) but rather looks like someone tried to skin it alive.
Shut everything down so I could remove all hoses and now that it seemed to at least be in better balance, try again.
Went to cut and got around the corner when, looking back (as I'd been doing a lot of) I see a geyser of oil spraying vertical.
I'm starting to smile now as it seems the Field Cutting Gods must not want their 5-6 foot high field cut....
The "T" that I put in, sits below a 4x4x2 junction box and is near impossible to FIRMLY attach without a crows foot. I do not have an approximate 1 3/4 crows foot..... so with everything hot to touch, used my cresent wrench to inch it backwards and removed it, putting the hose directly back to the input.
Note to self, I need to get a set of large crows feet wrenches.
Went about cutting and it still lays the VERY tall grass over from time to time but otherwise is getting close. It might not be exact. Heck, it might not even be "in the ballpark" but that said, the ballpark seems to at least be in view.
The life of the experiment on the gauges was very short lived but was enough to allow me to make that adjustment. I'll replace the hose and try it again but with even more attention to the routing of the hoses. Seems the blades really don't care what confronts them.
