Time to re-tire the car hauler
   / Time to re-tire the car hauler #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
Going to need to move the 3038e & realized the tires on the aluma car hauler were overdue for replacement. It's been sitting a few years since I've taken to leaving the 3038e at the acreage & the tires are 13-14 years old now.
Pulled it down on the drive & propped it up on the rear legs & jack to pull the wheels.
Dropped them off at the tire place, tires (4+spare) should get delivered/installed tomorrow & I'll pick them up to re-install.
(the 3038e will be going into the shop to get some rear remotes for a hydraulic offset flail)
  • Good Post
Reactions: 1hp
   / Time to re-tire the car hauler #2
Good idea, mine only had a couple of thousand miles on them but were the same age and starting to crack a little.
   / Time to re-tire the car hauler #3
Replaced tires this year that were on trailer for 13 yrs. Way too long, had blowout with tractor and bushhog loaded on trailer. was afraid the other tire was going to blow on that side due to weight change but got lucky. Unloaded tractor and put a spare on. Next day took trailer and had 4 new 8 ply tires put on . Next time pulling tires around 7-8 years of service.
   / Time to re-tire the car hauler #4
Lol. My heavy hauler trailer (14,000lb) I bought new I think in 1999 is still on the original Goodyear tires it came with. But then it has always been stored inside and has very few miles on it - tires still look like new. I do check them carefully before using the trailer for cracking, checking, any sign of weathering but they still look great.
New shoes!
Torqued the lug nuts & put it away til needed.
   / Time to re-tire the car hauler #6
(y)
I just replaced all 4 on our car hauler this spring. Original tires from 2002. Probably less than 5K on them. Parked out of sunlight all the time, but still, started showing some cracking. Not worth the potential problems.
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A56435)
Neckover GL24-2-7K...
SKID STEER ATTACHMENT MAINTAINER BLADE (A58214)
SKID STEER...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
2014 MACK PINNACLE (A55745)
2014 MACK PINNACLE...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
