Newbie to FCC registration, license, etc.
   / Newbie to FCC registration, license, etc. #1
Hay Dude
Super Star Member
A Hay Field along the PA/DE border
Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
I applied for FCC licensing. As I understand it, I need this for 5 watt radios? Or am I way off?
Basically, I want to buy a base, CB’s for trucks & farm tractors and maybe 2 hand helds.
I registered, but now what do I need to do?
   / Newbie to FCC registration, license, etc. #2
CB's do not need a license only Ham radio and power does not matter you need a license for all on Ham. CB are "supposedly" only 5 watts on AM and 12 watts on SSB but alot of folks bump them up for more range. Even a Base CB will be 5 watts on AM BUT the base mounted antenna will help quite a bit with your usable range!
   / Newbie to FCC registration, license, etc. #3
   / Newbie to FCC registration, license, etc. #4
...BUT the base mounted antenna will help quite a bit with your usable range!
Is a regular half dipole still the preferred antenna? Do they still ship them long, and leave it to the user to trim/tune them? If so, you'd do well to find someone local with a VSWR meter or network analyzer, to really get the best performance out of your antenna in its installed location.
   / Newbie to FCC registration, license, etc. #5
GMRS also needs a license I believe.
   / Newbie to FCC registration, license, etc. #6
I am not sure I have not had any CB stuff for years all Ham now.
   / Newbie to FCC registration, license, etc. #8
What range are you needing? If it is for business use that may dictate what frequencies you can use as well.
5-10 mi
   / Newbie to FCC registration, license, etc. #10
Cb are 4 watts and no license is needed for use. GMRS does require a license and is a "family" license (anyone residing in your household). GMRS is easy online application and good for 10 years. Then there is the Ham license. Several flavors for what you want to do. Need to pass lower levels to proceed upward.
Sounds like what you may need is GMRS radio service. Although CB can sometimes give you that distance, it's mainly flat open ground. GMRS will give a more reliable service without needing flat and open ground. Then with GMRS, you could put up a repeater or be able to use one if nearby. I hear guys on repeaters that are 50 miles from my location while mobile. You can drop quite some coin on GMRS quickly!
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
377811 (A48836)
377811 (A48836)
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2020 Case IH 8250 4WD Combine (A50657)
2020 Case IH 8250...
