Do You Have a Tractor Shed/Barn?
   / Do You Have a Tractor Shed/Barn? #181
Just following. Looking at these steel tube shed kits for camp property use.
Have you found any that are specifically suited for high snowloads? Whats your ground snow load, i imagine its high? We are 108psf. Ive been looking at the versatube and competitors, they say they will design for any snow load but im still leaning toward a wood frame since that is what I know and do.
   / Do You Have a Tractor Shed/Barn? #182
We did ask a builder that very same question. We are looking at 150psf if the construction ends up in a lake zone. But we have looked some that are not in it..
   / Do You Have a Tractor Shed/Barn? #183
I built this over the summer to hold implements. I looked at the investment I have in implements and felt it was not good to have them sitting in the hot sun/covered in snow all winter. I plan to enclose 3 of the sides next spring.
It is only partially filled in this photo.
I have an RV shelter that the tractor sits in.
   / Do You Have a Tractor Shed/Barn? #184
The RV shelter looks like one of those tube frame kits. If so, how was it to assemble?
   / Do You Have a Tractor Shed/Barn? #186
   / Do You Have a Tractor Shed/Barn? #187
It was a pre-fab kit. I purchased it with installation included. The pros got it done in about a half-day, maybe 3/4 of a day. would have taken me considerably longer. Plus I did not have to walk around on the structure like this.
It is 24 wide x 35 long x 12 high. I can get the 32 foot RV in it as well as my tractor, boat and two small utility trailers.
   / Do You Have a Tractor Shed/Barn? #188
I know you get some snow up your way, did you source the kit?
What is the size of that implements cover?
The implement cover is 40 feet long by 10 feet wide. I wanted to add a few more bays but ran out of room.
I do worry about the snow load on the RV shelter. if I see more than 2-3 feet building up I go knock it off.
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
gps trailers (A56859)
Toro Sand Pro (A56859)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
